I have sold my car so i now have no need for this turbo which i purchased last year.
The Turbo is an HKS T3G, which is what HKS now call the 25-30.
I am pretty sure it 350hp,(So good for 200-230rwkw)
It is based on the Garrett T28, as most of the HKS bolt on range are. (oil and water cooled)
Turbo has been freshly rebuilt, and has not been used since rebuild.
Lines and fittings are included, including a 3" Dump pipe, Braided oil line, water line banjoe bolts and the oil return line, with gasket, fittings and bolts.
So basically everything needed to bolt this turbo straight up to an rb20-25.
Im am asking 1100ono and would preffer a Melbourne buyer,
Thanks
Blair
0411 289 930
hey mate, is this turbo roller bearing?
Thanks, Mike.
https://www.sau.com.au/forums/topic/108588-sold/#findComment-2000747
I gaurantee it has not been rubbing on the housing, Has not been used since rebuild and balance...
It is the light in the picture reflecting of some blades but not the others,
The black stuff on them is a bit of residue off the tape i have covering the housing. Part cleaner, or the turbo in action will blast that right off...
Yeah, I think you'll find the shaved section - or the bit on the wheel that looks like it has been rubbing - is actually the balancing marks. They shave tiny amounts off the turbine wheels to make sure they are properly balanced - this is perfectly normal.
Where abouts are you located?
https://www.sau.com.au/forums/topic/108588-sold/#findComment-2032691
  • 3 weeks later...
how many kms ahs this turbo done, how laggy is it, and where is the power band? any shaftplay? and can u run this without ecu and injectors so long as u running standard boost, as a temporary thing?
https://www.sau.com.au/forums/topic/108588-sold/#findComment-2128025
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
