Hey ppls,
thought I'd bump this thread back up..
I do remember a discussion a little while back revealed there's quite a few ppls on SAU that have Internode as their ISP.
A quick question.. How do you find their relatively new Premium Usenet service since retention has rose close to around 40days. :)
Its awesome on dsl2. :)
meh :)
Another note...ive got my new rig almost together :) cubes, get round here with that damn cd with all goodies i need to get it going :)
BF2 here i come.....:)
meh im over BF2 but will still play with SAUers
i had my CPU fan stop working on me sat. night so had to buy a new 1 sunday :)
im on internode at home, but its always d/c and i never get full speed, it only gets max 6mb, usually 3mb :D
on an other nite, my mum wants a laptop so im gona sell her mine (8 months old dell inspiton 6000 with all the extras) and get a new 1...any suggestion on wat types? might get another inspiron, only looking 2 spend 1800 max, and this time with a decent 3d card :P
im on internode at home, but its always d/c and i never get full speed, it only gets max 6mb, usually 3mb :)
lol u never did end up getting a gfx card for your lappy the new Dell looks good but bit dear
Dell XPS lappy
I dont think it will :)
How can they have a running game already made, when dx10 cards dont even exist yet??
Dx10 cards would be out for Developers
on a side note might have to sell my PC as im told by Andrew @ Tillbrook's my timming bellt is making a racket and sounds like the bearings need replacing (im guessing cam gears have bearings) so depending on what Steve @ Manta Racing says i think i will be selling my PC and getting sumthing cheaper for the mean time and putting the rest in the car
so if you know any1 looking for a PC i can get the specs of it and i can tell u it wont be cheap (its a Gamers Rig but might take my $1000 GFX card out not sure yet)
more news as it comes :blink:
Nothing to do with the cam gears it will be the cam belt tensioner/idlers. You'd know about it if the cam bearings went.
You have a couple of options.
Press off the external ring and buy a bearing suitable from CBC for around $30, so $60 in total for bearings for the idler and tensioner + what some one charges to press off and on.
OR... Head to holdens and pick up two vl rb30e tensioners for $80 each. So $160 in total + labour pulling the radiator out, harmonic balancer cam belt covers then replacing cam belt ($90 from nissan) if it hasn't been done already, if replacing cam belt its wise to do the water pump ($80 for a good quality aftermarket waterpump). oh and + coolant another $30 odd possibly a/c pwr and alt belts if required.
So just there thats $360 in parts. + labour that should take no more than 2 hours. Unsure what mechanics charge today. Lets say worse case $100 p/h so you could be up for close to $600 for a major service.
IF you decide to buy an idler instead of the tensioner just the idler is around $280 from memory, or was it $180.. Most likely $180.. Stupidly priced. Grab a tensioner as they are a locking tensioner so essentially an adjustable idler. :thumbsup:
chears cubes food for thought :thumbsup:
ive been given 2 quotes $820 from 1 place w/out waterpump and $1250 with
i think i will be doing it with a mate
hes not sure about the harmonic balancer and how to put it back on though ..
does any1 have a workshop manual for these engines or that really isnt needed?
To remove the harmonic balancer you will need to buy a cheapo $19 balancer puller from supercrap/motor mates etc.
It comes off easily.
To put it back on simply push it on by hand a little, place the bolt in and screw the bolt back in, as it does it pulls the balancer back on.
Cheaper aftermarket cam belts can be had for around $40 but the Nissan belts come with white markings on them so you can line up all the points easily. Definitely worth while as you don't want to throw the cam timing out a tooth or two.
I have a 33 workshop manual. :thumbsup:
I think the tensioner bolt snapping is more so related to the stud not being replaced and overtightened. So.. ensure the $2 stud is replaced and torqued up to its correct settings. Same goes for the harmonic balancer, use the old bolt but be sure to lock tight it and torque it up correctly.
  • 3 weeks later...
Bumping a thread here :)
Got my system running finally, bar 1 or 2 things....
Just wondering what programs people use to bench their system? Ive got 3dmark06 here, and superPi, so ask and ill do some tests @ stock speeds.
Also wondering about how u guys oc your machines....(im a noob oc'er :O)
I usually find the maximum the ram is able to handle..
Keep the cpu near stock as possible speeds and ramp up the ram speed. Use memtest to find its limits.
Then drop the ram back down.
Now ramp up the cpu speed and use prime95 to find its sweet spot.
I usually do this by ramping up the speed until it requires a few volts to be stable, the sweet spot is where you need large increases in vcore to achieve only a small increase in cpu speed. Heat usually becomes an issue but as you are running water you shouldn't have the heat problem. :O
Then you know the limits of both the ram and cpu. Now try to find the closest speed attainable for both the cpu and the ram. :)
um i got the nice gear but dont O/C :O (its auto set on turbo in the BIOS)
i use 3dmark 05,06
super_pi_mod-1.5.zip
and my 3dmark05 score is 10,142
http://service.futuremark.com/compare?3dm05=1999050
NOTE my 3dmark score i primarly my gfx card score not MY CPU its benched best in dads chepie PC :) a AMD 3700+ with 1gb of kingston ram all running stock
**EDIT**
get CPU-z from here http://www.cpuid.org/cpuz.php
Edited by Madaz
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
