lol Cubes I'm suprised Antec would be so dodgy with using those caps? They're meant to be a top tier manufacturer. Speaking of caps, one of these caps blew on me last week on my car's ECU whilst driving in the country at midnite;
Woohoo stranded in the middle of nowhere. Not fun. Bloody capacitors.
Edited by Busky2k
lol bugger..
Those caps are supposed to be ok but not suited to the temps of a psu.. :miner:
Madaz.. Yep I've noticed mainboards are now starting to go solid state caps, taken their time. Vid cards have been solid state for quite some time. :laugh:
Its quite funny as electric guitar amps have been solid state for a while now.
Whats even funnier is the preferred electronics for the guitar amps is the good old glass tube valves :P Apparently produce the best sounds, but u need to replace the tubes every year (or as needed)
Edited by Bl4cK32
im running an antec trupower 2.0 550watt power supply to run an e6600 and a 7950gx2 (which im selling btw) and no problems so far whatsoever... still early days but i like the way this psu operates... now if i can get my bloody water cooling working properly.. i got Castrol coolant running in the mofo and still it dont like the hot weather. the ambient temp and the water temps are killing me. the fan that came with the e6600 was better. when i open the window at night tho the fanless radiator gets working and fresh cold air always is the go for any equipment that dissapates heat.
u need fans on the rad to see better temps than a passive system. Same as a car needs to move to keep it cool :(
methanol and what?....
i heard people using Reverse osmosis and anti freeze solution but i dont have any anti freeze on hand. just the RO water.
the unit im using is a Thermaltake Rocket fanless radiator water cooling system. performance is heavily reliant on the delta temperatures and therefore if its 30 degrees in the house its going to be nearly 50 degrees on the CPU in idle and the CPU is an E6600 which means max safe temp is 60 degrees... dangerously high.
when i run the aircon and get the inside temp down to 24 or so the cpu runs like a dream and does not mind a heavy overclock at all. ~36 degrees idle.
on whos opinion. a proffesional one or yours. my system makes 0 noise practically. only 1 fan needed now. i wanted to sacrifice as little as possible including the price of a system for silence.
yeah that is a pretty harsh comment black32. I suggest you talk to the dozens of high-end PC techs who use Thermaltake all the time and never have a problem with them, me included.
I have a 480W Total Watts Viewer in my current rig and it works flawlessly .... and I overclock it like a biatch. I am running a power thirsty XFX 7600GT, o/c 4200+ @ 5800+ speed, 4 case fans, 2 DVD Burners, 2 SATA hard drives and 2 IDE hard drives, and it doesn't even break a sweat (and I know this as it came with a 5.25" bay digital readout panel of current watts usage). It is silent (but comes with fan speed controls also), and runs smooth as.
I think your comment is far too subjective - maybe you should read the thousands of good reviews of Thermaltake power supplys that litter the internet.
FYI with all of those parts listed, my PSU still only runs at 96-100W at idle and 160w in-game.
When heavyweight guys like TomsHardware are utilising a Thermaltake PSU in the 'dream rig', you would have to think the quality is top notch?!
http://www.tomshardware.com/2006/11/21/ibu..._gaming_system/
or when you read reviews like this? (on my specific PSU)
http://www.bigbruin.com/reviews/totalwattsviewer/index.php
or the hundreds of raving favourable reviews I found on a quick Google search including this one
http://www.overclockercafe.com/Reviews/oth...V480/index.html
Maybe every reputable IT website who does these reviews is completely wrong and you are right?
My 2c :(
aaaaaaagreed. i think tho i am going to hand this thermaltake rocket back for a thermaltake bigwater or something similar. bigwater seems to be loved by alot of enthusiasts for price and peformance. id favourably make one myself but then Id have to pick a good pump, resevoir, radiator etc... if i could get my hands on one of the 240v powered server chassis fans from work and install that beast and didnt have to put the computer 200 mtres away from the screen and kb/m then id do it but they are too f**ken loud.
Ok for starters i was referring to the thermaltake line of watercooling kits, so hope that clears it up for you both.
2ndly do a bit of research on OCAU in the extreme cooling section, and ask what the guys there think of the thermaltake kits. Ive seen numerous results that prove and show thermaltake is one of the worst kits in performance when watercooling. Not talking professionals, we're talking user end reviews of heaps of ppl who use the kits day in day out, not some random who reviews a kit on a once of basis and gives their 2c.
Without me doing any hard searching (which u could do)
http://forums.overclockers.com.au/showthre...rmaltake+rocket
http://forums.overclockers.com.au/showthre...altake+bigwater
http://forums.overclockers.com.au/showthre...ght=thermaltake
etc...etc....the list goes on
FYI - toms hardware arnt the most reliable sources...
If u want diy look at the swiftek range of gear.
Watercooling + PSUs/Fans are a different story mate.
We use Thermaltake in the corporate environment to beef up the fans on our mid-level pc's. Very happy with them for cost, performance and noise. I know of at least five major adelaide-based multinationals that use Thermaltake products, especially in our hot dry environment here.
I wouldn't hesitate in recommending their products to my colleagues.
lmao...who is linking what i origionally said to thermaltake psus???
I made a reference to the watercooling kit which SAzilla was talking about. Nightcrawler jumped to the conclusion i was referring to all thermaltake products.
I own a thermaltake case, and its the best case ive had :D I dont have a problem with any of their products besides the watercooling kits...
As for the psu's the bundled ones with cases are known to be shiet - http://forums.overclockers.com.au/showthre...rmaltake+psu%2A
However, Thermaltake thought it necessary to stick a label on this power supply that declares an output power of 400W and even promising a peak output power of as much as 500W! But as I made sure in my tests, even 300W is too high a load for this power supply. Depending on the particular conditions, either its overload protection reacts, or the attached system hangs up due to a sudden drop of the output voltages, or the unit just burns down. And the XP480 comes in system cases that can hardly be called cheap: the retail price of a Tsunami Dream is about $140. This case is unlikely to be bought for a low-power office machine I guess."
Edited by Bl4cK32
thermaltake case, antec psu and watercooling kit by thermaltake whcih makes no noise but performance relies havily on surrounding air flow and temperature
i think im gonna find a custom pump and radiator soemwhere but ther waterblock for the CPU is sweet as. for the other parts i cant say the same.
ah cool mate, sorry I misinterpreted what you said .... Thermaltake cases/PSUs ftw :D
I haven't used their water cooling products, but find their heatsinks/fan setups to be very good. I never got into water cooling, always found the idea of water running through my PC way too scary!
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
