tem: 1995 Nissan Skyline R33 GTS-t
Website: http://www.skylinesaustralia.com/forums/in...howtopic=109628
Item Condition: Great
Reason for Selling: Looking to downgrade, need cash
Price and Payment Conditions: ANY OFFER OVER $17,000 WILL NOT BE REFUSED!!!
Extra Info:
Engine:
-Highflowed standard r33 turbo
-3"dump pipe into high flow cat, 3 1/2" cat back HKS exhaust into X-Force Cannon w/ 5" tip
-Apexi electronic boost controller
-Hybrid front mount intercooler kit w/ 600mm/300mm/76mm intercooler core
-Wolf 3d fully tuneable aftermarket ECU with hand controller
-Simota airpod filter
-Iridium Spark Plugs
-GTR fuel pump
Driveline:
-Standard 5 sp box with heavy duty clutch
Body:
-Modified front bar with centre section cut out to fit intercooler, and repainted
-Series 2 rear wing
-nismo decals under side repeaters
-HKS decal on boot
Brakes/Suspension/wheels:
-Standard r33 calipers and rotors
-Bendix ultimate pads
-HSD fully adjustable coilovers with height/dampner/camber control
-19" 5 spoke shadow chrome wheels, with polished dish
-235/35/19 nankang front tyres, 235/35/19 marshall rear tyres
Interior:
-Apexi AVC-r controller dash mounted, can give guage readouts for speed, boost, revs, duty cycle etc
-Wolf 3d hand controller
-Dash repainted in white same colour as the car
-all seats and trim standard r33 gear
-genuine momo alloy gear knob
Stereo:
-Sony CD headunit
-Kenwood KFC-M7145IE 500W 7x10's Front Speakers custom mounted in the doors
-Kenwood KFC-M7145IE 500W 7x10's Rear Speakers fitted in custom parcell shelf
Has all the standard features of the gtst including power windows/mirrors, climate controlled air conditioning (18-30 degree range) drivers airbag, leather wrapped steering wheel and gear boot
- Made 300hp/230kW atw on 1.1bar boost (16psi)
- Serviced every 5000km/s with synthetic oil etc
- Mainly ran on standard boost (7-8psi)
-Had approx $20,000+ spent on it, and most mods done within the last 18 months
Any q's give us a txt or call on 0407217325
Pictures: Clicky
Contact Details: 0407217325 or 0265834374
Edited by Satanic_R33
https://www.sau.com.au/forums/topic/109628-sold/
  • Replies 62
price neg,
willing to swap for anything 5k-$15,000 plus cash, let me know wat u got, open to anything
Just had Castrol Fully Synthetic Oil change/filter, iridium spark plugs and fuel filter done over the weekend
https://www.sau.com.au/forums/topic/109628-sold/#findComment-2110720
i got a candy red honda integra 95 model vtir selling at 16500 ONO... i havent got cash to give u as ur cars for sale at $20500... if u want work out something with taking a few extras off ur car and get back to me if ur interested for a straight swap..... if i did have the cash i woulda considered something but as i am after something around my price range for a swap.. cant find no one.. :D Good luck with the sale neway if ur not interested
https://www.sau.com.au/forums/topic/109628-sold/#findComment-2173403
Firstly nice ride hey :D Mate I've got an R32 GTS-T was looking for around $15K. Pretty stock, cooler, 3inch turbo back exhaust, 18 inch tyres, Alpine stereo,painted interior, will have fresh respray soon. Goes really well, regular oil changes. Rego till September. Not sure about cash aswell but its on the table anyway.
Cheers
https://www.sau.com.au/forums/topic/109628-sold/#findComment-2194855
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
