  • Replies 106
Posted Images
can get hold of a standard turbo, is it possible to bolt straight on or would i need to take to turbo place to get fitted? looking for cheapest way out right now as getting bigger turbo would cost me heaps to repair everything else
@ richmond u have Steve from Manta Racing (Manta Automotive Services)
hes a top bloke and wont steer you wrong and he knows his stuff when it comes to GTR's and skylines
he replaced my whole front diff without taking the engine out and keeping the cost to a minimum and he warranties his work (labour) for 12months
I'd suggest taking it to Bill Keen at ATS on Marion Rd to get Hi Flowed, May as well while it's off the car........and you will get more power than just leaving it standard and won't have to spend 1-2.5k on a aftermaket turbo as soon or if at all. He will prob be able to fit it for you also.......Otherwise as always take it to Shaun(Boostworx) :D
Darren
Darren i was impreswsed with Boostworx, they haven't sorted out the problem with the pinging yet but are getting some more stuff (ecu ect.) to try. They checked all the timing, mixtures and the standard ecu and it didn't come up with anything. Turns out my "standard" skyline has a few after market bits like the oxyen sensor which may be causing the problems.
Starting to think i might sell this 33 and save up for a GTR
^^^^^^ Yeh sweet Nick nice work, Shaun and the boys have work on a few cars of my mates now(white Evo3, pink Rx7 ATM and heaps of people's on here) and i i hear is good stuff from him!
GTR hey, You could hook up with Shan(funkymonkey) on here who is J Spec, I spoke to him about 33 GTR's when he was here and was rolling off some very good prices for them, maybe keep that in mind!
yeah i saw the pink RX7 and the EVO in there. It's alos good for me being just around the corner from work, had to get a manager to drop me off to pic it up this arvo.
I just hope they can sort out the problems with the timing as it is really annoying me especially now i have to miss out on another cruise
Ummm, maybe a SITC might help? Have a look into it..... SK's thread http://www.skylinesaustralia.com/forums/in...c=80642&hl=SITC
I dont really know, but I use a Apexi Super-ITC, ie an Ignition Timing Converter. Mainly 'cause I run auto, but also it links well with the SAFCII, both being Apex etc. ~$220 USD on ebay, generally $300aus delivered, 2nd hand........ I managed to snare a new one there for $20 less, but around $300 is the go.
Can adjust a fair bit of timing into 5 rpm spots, not saying it will help your particular timing issue but definately an excellent tuning tool (with my sitc/safc/ebc & mods I expect ~210Awkw with a 500hp turbo)
Edited by Tangles
oh u made a comment in the thread i posted when i needed my diff done i thought u had urs done once too
if u get a 200+ AWK combo happening i suggest u look into GTR crown and pinion gears otherwise ull do wot i did and strip ur gears
Edited by Madaz
i dont know this is wot ive been told by a very good mechanic that the R33 GTS-4 DIDNT come with turbo and had a ratio of 3.4 and has too much power and torque for the drive ratio :S
R32 GTS-4 (RB20DET) came with 3.6 and all GTR's came 4.11
Ive always had the impression the R32 GTS4's have always had the 4.363:1 diff ratio.
http://www.skylineowners.com/forum/showthr...goto=nextnewest
There's a little thread also.
I'd hate to drive the RB20DET GTS4 if it really did have a 3.6:1. :nyaanyaa:
  • 5 weeks later...
not happy with boostworx now. rang them this week to fid out what was going on with my car. They started out reassuring me that it was a detonation problem, then they were trying to tell me I had a series 2, when i have a series 1.
Had one of the mechanics at work who had a 33 GTST and he said either the turbo or exhaust manifold (which is also what cubes suggested) had a look today and the one of exhaust manifold studs has broken off (can't tell if any of the other ones are).
Any know where I can get this fixed and roughly how much it would cost?
I was thinking about going to Adelaide turbo services on marion road this week and getting a quote from them
Edited by Whiplash
Out of curiosity.. Which stud went? I've seen a few rb's where the cyl one and two studs go before the rest.
Was it shaun u spoke to at Boostworx or the new bloke I saw there a week or so ago?
I've been talking to shaun the entire time i have been dealing with them. Was disapointed with it as I was happy when I got my car serviced there, after all the good stuff I've heard about them in this thread
the one closest to the firewall. The other end was loose but we didn't want to tighten it up incase it broke off aswell
The mechanic that helped me this morning said he would take it to work and it would take a few days to repair and will cost a bit as the manifold usually need machining to make it flush again if the studs have been broken for a while, which looks like the case here.
I'd hate to drive the RB20DET GTS4 if it really did have a 3.6:1. :O
well all i know is pete from willal racing sent a R32 ratio over to steve @ manta racing and steve said the ratio was 3.6 and we wanted 3.4
When I pulled the old motor out I was suprised there wasn't any noise as the first and rear cylinder had broken exhaust studs, 4 studs broken in total.
I didn't bother machining the exhaust manifold and its been fine for 40,000km's, I've been watching the block for any black crap. :O
Apart from that its not hard to do, I can have a turbo pulled off within 1.5hrs, takes about the same to put it back on. To remove the studs stuck in the head was suprsingly easy. Some may not be so lucky though. ;)
Its important to torque the exh. manifold nuts up to specs as if you don't you will break more studs.
Its scary how loose the torque specs are, it felt like only just past finger tight. :D
Bl4ck32 when doing his also commented on the lack of torque required.
So is it possible to do it at home or am i better off paying a workshop to do it?
The machanic i had around works out at Agastino Mitsubishi and said that it usually takes a couple of days to drill out the stuck studs and replace them
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
