Hey guys i need to find out wat my cars doin and wat could be the cause...Im kind of worried and would really apreciate all the help u can give, I know this is long winded just giveing all the info i can,
Background: I have a 1989 hcr32 4 door, genuine 71thou kms with log books, was auto converted to manual (not sure if the auto comp is still attatched, , every thing was goin fine after the conversion, K&N Pannel filter, X force Front pipe(fitted 100kms ago) no catback thou, besides that compleatly stock, serviced every 5thou, im using Royal Purple motor oil, and Redline gear oilive put 13 thou km on it
Problem: The last 2months (2 tho kms) b4 my last 5thou km service, when i started the car cold the revs wouldnt build and wouldnt kick over unless i tapped the gas peddel it then starts and idles fine, 3 weeks ago i had it serviced and the problem is still there, wat i am also noticing is that it revs high at idle some times like 1500rpm but then drops to 900rpm, and when the air con is turned on its only adjusts teh revs some times but some times they drop to 400rpm, i get really bad Km's out of a tank. even when i drive like a nan, i know im driving a skyline and i expect high consumption, im currently on this tank of petrol see exactly wat i get out a tank but at 3/4 tank 86kms??? driving really rev less,
Thoughts: Some sensor isnt working, like teh sensor that determines idle speed and cold start, ??? : 02 sensor? i dunno
I hope that infomation helps and any questions that would help diagnose the problem please ask.
Thanks Guys
Brett
https://www.sau.com.au/forums/topic/111612-rb20-start-and-idle-problem/
Try:
Cold start air valve, located under the plenum (near #5)
Auxilliary (Idle) Air valve, on the back of the plenum
Water temp sensor (single pin sensor, where top radiator hose joins inlet manifold).
  • 3 weeks later...
Cold air valve is that same as PCV or PCM Valve ???
and
Water temp. senor
How can i check those twon are in good working ?
i didnt end up doin any of that,
it ended up being a fuel line, with 17 years that kinda stuff is gonne be sus,
it was the fuel line from the fuel pump into the filter,
so yea chaged it, and starts like a dream,
cheers
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
