  • Replies 45
Gday Scott,
Most of the work was done before i got the car, the exhaust is Xforce, not sure about the cooler?? the clutch is An Excedy sports organic clutch... lotsa bite, i did have receipt for the clutch around somewhere, but if you test drove it you would know its a sports clutch!!
https://www.sau.com.au/forums/topic/111899-sold/page/2/#findComment-2200532
hi im looking to swap my little beast. iv got a white rx7 s4, whats done to the car,
- 13bt
- pod filter
- its got a brand new BN sports body kit (just in matt black for now)
- Mazda 6 17"wheels with 215/45/17 on front and 235/45/17 on the back
-3 inch into two 2 3/4 duel pipes (straight through exhaust)
-lowerd with king springs and kyb damper adjustible shocks
thats about it really.
the interior is good as new but has no head deck cuz i got the car 3 months ago and havn't been botherd to put one in :wink:
it has rego till march next year and there is only 83xxx km on the clock.
ummmmm thats about it, so if anyone is interested let me know,
https://www.sau.com.au/forums/topic/111899-sold/page/2/#findComment-2266427
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
