Selling my R33 Skyine Series 1 1993
Info:
- Auto
- 105,000k's major service has been done for the 100,000
- 12months rego
- All standard option (Climate control, power steering, HICAS etc)
- Service every 5,000km with Penrite
- Aftermarket suspension (front adjustable)
Engine:
- 3inch exhaust from turbo back with cannon muffler
- Custom dump pipe off the turbo
- HKS Pod filter (modified to make big flutter)
- Turbosmart Boost controller
- HKS Front mount Intercooler
- GTR Fuel Pump
- Remapped Computer
- 168kw at the wheels on 7psi and 210kw at the wheels on 14psi
- Automatic counting Turbo Timer (Counts depending on turbo heat)
Extrior:
- Custom Chamelion Paint job inside out except engine bay black.
- It was sprayed about 5months ago. took off all badges including GT ones on the guard.
- Full bodykit (Front has been customized to take out the number plate gap)
- Stealth rear wing
- 19inch Speedy Sphere Rims with 90% tread Machine Finish
- Lowered almost to the rims
- Tinted Windows
Interior:
- Dash and other pieces in the car painted Chamelion
- Newly fitted GTR Dash (Not in pictures)
- 3 Gauges on pillar Defi Style (Boost, Volts and Oil Temp)
- Aftermarket Shifter
- Panasonic MP3 Player
- 2 12inch Subwoofers in the boot
- Cadence Monoblock amp
- Sports steering wheel
This car is imacculate and body is extremely straight
Im asking around $24,000ono
Any other questions just call me on 0401 670 923
Edited by sic.vlt
https://www.sau.com.au/forums/topic/111958-chameleon-r33-slyline-fs/
  • 3 weeks later...
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
