Updated prices...
- Tanabe sustec pro adjustable coilovers - $800 ono
- Castor rod brace - $70
- Exedy HD clutch/pressure plate with SR20 flywheel - $250
- S14/R33 rims with good tyres - SOLD
- HKS EVC-EZ (electronic boost controller) - SOLD PENDING PAYMENT
https://www.sau.com.au/forums/topic/112154-sold/#findComment-2078242
Updated prices...
- Tanabe sustec pro adjustable coilovers - $750
https://www.sau.com.au/forums/topic/112154-sold/#findComment-2089683
