hey all
got a question for you skyline gurus (suprise!)
with the exhaust i got with the car i the previous owners welded the restrictor into place, theres a bolt underneath but all it does is freespin
the engine drives ok at low revs but it sort of dies or lacks power at high revs
does anyone know what exhaust it is?
i asked a guy from a exhaust shop and he said to just cut the restrictor out
is it just as easy as that?
ps it has the jasma plate on it aswell
thanks
:ermm:
https://www.sau.com.au/forums/topic/112185-is-my-baby-choking/
do you really like that tip? cos you could just buy another one to replace it.
either that, drill a hole in it. then hack it out with a reciprical saw (motorised hacksaw)
up to you, looks wise id get a new one personally
Those restrictors are very common on various makes of Japan exhaust systems. Sounds like the previous owner got done with epa and decided to comply and lessen the db levels. Unfortunately, it really restricts mid to high rev performance.
The solution is as easy as cutting the welds off and removing the restrictor, but the db level will increase dramatically.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
