yeah unless they dont know that the car had ABS from the start?
I have an S2 R33 with drivver/passenger airbag. mine arrived from japan with a momo on it and it passed compliance ok?
I doubt any authority would pick up on it ...
https://www.sau.com.au/forums/topic/112786-steering-wheels/#findComment-2079870
Hi,
Just quickly, does anyone know about this nismo steering wheel like where to buy it in australia and if it fits the hkb boss kits for an R32 gts-t. I really want to get it but dont know where to get it.
Thanks
looks like an ordinary momo with a nismo horn button to me
https://www.sau.com.au/forums/topic/112786-steering-wheels/#findComment-2080069
