Hey guys another silly question is there two different types of vg30dett one being a DET not TT also if there is are the turbs different one being steel wheeled i got told i was buying a steel wheeled vg30DET turb but not sure how to tell wat is wat if its steel wheeled wats the safe boost level ADRNLN Billy got this turb for me so hoping its all good he said it good for 18psi but i only want 14 to 15 psi will it cope..... :O
https://www.sau.com.au/forums/topic/113111-vg30-turb/
if its on your car already and running ...... its pretty easy to work out if its a DET version.. she wont make full boost to around 4000rpm
laggy sons of bitches on the 20s..... but great fun i reckon.
some where steel wheeled.. in the earlier Leopards and 300zx's .... most of the later ones are ceramic rear..... 15psi would be safe amount to run without leaning too hard on the motor or the turbo if either of the 2 arent in 100% working condition.
OP6 on teh rear housing is what u gotta spot before u cough up bills for turbo.
mine cost me 150bucks....lol few months of boost .. freed it up and it stopped making shitty bearing noises..... but gives me the impression its bush not ball bearing'd
Matt
https://www.sau.com.au/forums/topic/113111-vg30-turb/#findComment-2085529
Thanks if thats the case im pretty sure its the DET version it doesn't start spooling till round 3800 full boost at 4600 got told it was because the cooler and piping i was running plus the timing is out i think. 600/400/100 i think pretty big all the same with 3'' piping on it and only 7psi. Will timing make the turb come in later
https://www.sau.com.au/forums/topic/113111-vg30-turb/#findComment-2085543
Matt
I agree Ithink some were steel wheeled. Also the Vg30det's came from the factory with forged internals. So obviously they were meant to handle more boost from the factory.
https://www.sau.com.au/forums/topic/113111-vg30-turb/#findComment-2085674
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
