Hi all
I have a used exhaust for sale. The flange is from the differential back (I am keeping the part from the cat to the diff).
It is a quality stainless steel japanese exhaust, brand unknown. The flange is 3", but the piping is 3.5" ALL THE WAY. Unlike cheaper systems, the piping, and the section through the cannon muffler is 3.5". Hence the flow is not restricted as it goes through the cannon.
Makes a great sound, not overly loud, a nice rumble to it. Fairly light weight, especially when compared to the stock muffler. Only one scratch on the bottom muffler (see pic), else the exhaust is in excellent condition.
If you look at the pics you can tell that the exhaust hangers are hollow to save weight. It is pretty much the same design as the Fujitsubo PowerGetter for the R34. I am pretty certain it will fit the R33 without dramas as I have put on a R33 exhaust onto my R34 before.
Location is Sydney, price is $200.
Straight bolt on for R34? Where you located in Sydney? Pick up asap for $150?
Actually.. want to sell the whole cat back? Getting a pipe from cat to the above might be abit fussy.
Edited by OnGsTa
Sorry the rest of the exhaust is actually on the car, cant separate.
All you need to do is go to a local exhaust shop and get them to make the part to the diff, pretty easy job and shouldnt cost that much. The most expensive part is the muffler.
I am pretty firm on 200, anything less and I might as well keep it to interchange with my existing muffler when I feel like a change as its all bolt on/off.
Edited by nuffsaid
So its not a straight bolt on? The stock exhuast on the 34 GTT from cat to rear muffler is one piece then?
It is bolt on, ie. it will bolt onto the existing hangers and even the hanger near the rear sway bar.
You just need to get the piping made up for it from the cat to the point near the rear sway bar or diff.
Sorry when I said bolt on I was implying direct replacement, i.e. take off old component and 'bolt-on' new exhaust.
Will have to consider it now as I thought it was straight swap. PM me with lowest price you're willing to sell or if you don't end up selling.
Thanks,
Andy
  • 3 weeks later...
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
