Hi guys,
I am selling my sideskirt and rear spoiler off my S15 making way for a new bodykit.
Dealer price for non painted sideskirt $590 and rear spoiler $580.
Side Skirt $300 SOLD
Rear Spoiler $250
Colour is pewter
You can contact me via email [email protected]
or 0410320021.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
