Hi guys,
does anybody knows what tyre size for the 260rs? The factory fitted bbs wheels one. I know its 17" and i got 2 different sizes on the net.
they are 225/50/17s and 245/45/17s dont know which is which. Chasing up some prices for the tyres before the car gets here.Thanks
https://www.sau.com.au/forums/topic/116304-tyre-size/
Hi guys,
Your tyre placard (fitted when complied) should identify the correct tyre size.
The 225/50R17 and the 245/45R17 are within 5mm of each other in diameter. Also rim width may determine which tyre is a legal fitment.
Your 225's will range in price from $210 to over $400, and the 245's will range between $205 and $500.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2138536
Check with the compliance workshop that is complying your car, they will most likely know (although being a 260RS they might not) they have access to good tyre prices in most cases so that may save you a dollar or two?
Luke
Edit: How many people on here own a 260? Not sure how much help we lowly RS Four owners can be to you...
Edited by munchdesign
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2138589
if your tyre size is not the right one wouldnt it effect the accuracy of the spedo?
im trying to get a tyre from good year. The model is GSD3 f1. It a good tyre. preety cheap compared to hankook and nankang for that size.
I dont know what the comploance place will give me for the tyres. I dont want cheap and nasty one.
BTW is rating Y too much for the ccar or right on par? Thanks
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139016
Check this thread you will find some of the info you are after in here, try seaching the forum also, it seems a bit hit and miss but there is a lot of info on here already.
Cheers
Luke
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139129
The bible (TRAA) identifies 'Y' speed rating @ 300km/h.
Whoever complies the car and attaches the tyre placard have a responsibilty to ensure the correct tyre is identified with respect to rolling diameter, speed rating and load rating.
Do not be too concerned about your speed rating, the load rating is the more critical.
For example the 245/45R17 F1 GS-D3 is a 94Y. That is the tyre has a load capacity of 670kg @ a max of 300km/h.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139607
which is suited for stagea? Im more concerned about the tyre grip. Load factor ok. Im very particular with tyres i hate michilens. i dont care how good you guys sya it is. it is POS!! so either im sticking with goodyear or perrilis p6(if they stil got them)
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2139689
Horses for courses. Tyres are a personal choice, some people are brand concious, others price concious. All the major manufacturers have some good tyres in their range. Your F1 GS-D3 is available in the 225/50R17,, but I have no listing for a 245/45R17. But I could recommend the 245/45R17 in the Toyo T1R for example. I personally run a Goodyear Rev Spec RS02 (235/40R18) on my Series II Stagea, and will be trialling the new Dunlop Sport Maxx on another vehicle shortly. I have had some very strong feedback from customers on this new tyre.
Wait until you know exactly what tyre size has been complied for the car and then look at the available options in that size.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2140143
if you want to keep the stock speedo accurate, use this website and find some aftermarket tyres to use with any wheels.
http://www.1010tires.com/TireSizeCalculator.asp
As far as buying tyres, just make sure you get same tyres front/rear. Replace all 4 at once. Rotate them maybe ever 6 months to a year, depending how you drive. Ive just rotated mine after 3 months and really needed to do. I do load up the front wheels quite a bit.
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2140498
they sort it out themselves and fit you the bill.
they will just use the cheapest tyres that are suitable unless you say otherwise.
a
im going to ask them to save the tyres themsekves abd i will give them goodyears GSD3 for $198/tyre 245/45/17s so...his tyre is very good.
the review for t
https://www.sau.com.au/forums/topic/116304-tyre-size/#findComment-2144146
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
