hey all
just wondering if anyone was interested in buying a pocket bike, its a replica of a thumpstar with a 125cc honda engine with a 25mm carbi. Comes with alloy swingarm, alloy handle bars, black alloy rims, alloy bashplate, heavy duty upside down forks, racing exhaust, front and rear disk brakes, high flow fuel filter, electric and kick start, 4 speed manual with clutch and a full set of black thumpstar plastics. can take 120kg of weight and has a 3L fuel tank which gets just over 60km's
(will post pics if someone is interested)
RRP from what i know is: $2000
price for sale: $1400 onoNOW $500
sydney buyers only.
plz pm me if u are interested
cheers
manveer
Edited by bLaCkMaN
https://www.sau.com.au/forums/topic/116503-sold/
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
