1994 Model 180sx
Has 12months rego and it was renew today
Was Imported and Complied In October 2005
Car was a Sev's Test Car so need to be in Mint condition
was a grade 4 car in japan at auctions
91,XXXKms
SR20DET Black Top Motor
5spd Manual
Unknown Aftermakret Jap Clutch
Jap Double Din CD/Tape Player
Tomei Short Shifter
Trust Power Extreme 2 Cat Back
Trust 3inch Front Pipe
Drift Pod Filter
Blitz RVIT
Momo Steering Wheel
Apexi 1.8Bar Boost Guage On Pillar
HKS Type 0 Turbo Timer
Rays Engineering Gram Light 57C Rims, 17x7.5 +30 and 17x8.5 +40
Dunlop Direzza DZ101 215/45/17, 235/45/17 Tyres 90% ($330 Each Brand New)
Full Respray in Flat White and Black at start of March, Engine Bay was also reprayed
GP Sports G Sonic Bodykit
AAR Leather Drivers Seat
Clear front and side indicators
This car has been taken car of, All fluids were replaced in November and Oil and Spark plugs were replaced after 2000kms just to make sure. Car has only done 3000kms in Aus as i dont travel far to work. Car was imported with 88,500kms
This car is one of the cleanest 180's i have seen
Car was Imported By Energy Imports in QLD
Car was Complied by Adrenalin Imports In QLD
All bodywork was done by Roshan from Driftline Racing in Vic.
Looking for $17,000ONO
Carsales Link
Edited by SLYSX
https://www.sau.com.au/forums/topic/117091-nissan-180sx-1994-model/
PRICE DROP TO 17K ONO
MYR33T - Thanks dude, yeah i love the car but iam looking at something else different.
Yeah my friend has a sexy 180 thats prety much looks exactly like yours... its his drift pig.. I love his car
  • 4 weeks later...
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
