Hi all,
I've been having this problem for about 6 months now, but I've been too lazy to fix it.
Basically I've got incredibly heavy steering - almost like I've got no power steering - and when I turn the steering wheel slowly, the revs don't rise like they used to. The fluid levels are fine, so it's not that. I had Mark at Hills hook it up to his little diagnostic machine and he said some sensor for the steering was screwed and not sensing properly (possbily on the steering rack? I can't remember). Does anyone know what this sensor is? This all seemed to happen when my wiring burnt out and I had to get it replaced (the guy in Japan did the DODGIEST wiring on his gauges).
I've also got error codes 22 and 32 for my HICAS which is kind of bad too I'm sure. I'd also like to get rid of that. Anyone know? I read a thread a while back that said if some wire from the speedo to somewhere else was missing, then the HICAS would give error codes. Does anyone know about this either?
Sorry for all the questions :D
Cheers,
Michael
https://www.sau.com.au/forums/topic/11851-heavy-steering-hicas-faults/
Yeah I'm pretty sure it's a wiring problem, as I had the whole thing rewired when it burnt out. The thing is though, when the steering wheel is turned hard, power steering kicks in. This would mean the right wire is attached. It makes it a bitch to drive in relatively smooth curves in the road as I can't always tell when the power steering will kick in.
Randy, I haven't checked it out as I thought someone here might have been able to just say "it's the XX sensor on your steering rack". I might have to take it in to a place like Whiteline if I can't resolve it myself.
Has anyone looked at their steering rack? Are there any sensors on it at all?
Cheers,
Michael
  • 1 month later...
Guest liamjones25
i had a similar problem while driving my r33 gts-t...
we were going around a corner at slow speed, and for some reason, the steering went incredibly heavy, like the power steering had cut-out and the HICAS warning like came on...
As to why this came on, i don't know... any help would be greatly appreciated!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
