Found something I want write now. Series 2 R33, so I want to know I have a buyer now.
$8,000 for the next two days.
Have an offer already, just looking to get a little more. Will take $8,000.
  • Replies 45
I have decided I will buy that skyline on friday. If I can sell this before than, I'll let it go cheap.
If not, I'll stash it in mums spare shed and wait until someone comes up with a better offer.
taking any offers around 8k today and tomorrow.
Id so bloody buy that right now... except my car is in pieces so I cant sell it to buy that... ; ;
If your still selling this when I get mine back together, consider it sold!
One of the last price drops I feel. A few people have expressed interest now but have reasons why they can't.
$7,500 now.
I really should make that WITH OUT the microtech, with a stock diff, with a T25G and with smaller rims.
At this stage that all still comes with, but I'll start selling things off soon.
I think its relevant to mention, I now own a series 2 GTSt skyline as of today.
Jumping from one to the other, as i can do now, i can say the gazelle is alot faster, more power, heavier clutch, much stiffer suspension, certainly more of a drivers car.
hey mate just wondering if youd swap a 1990 nissan exa with 17 inch chromies exhaust bodykit not fitted colour coded plastic interior parts and more nice looking car worth about$7000 i really wanna get into drifting call me 0434895812 or leave a msg cheers
Not really after a swap because I really do actually have a Series 2 skyline now.
Also, I'd only swap a car which is easy to sell cause thats all I'd be doing and an exa isn't easy to sell for $7,000.... if it is, sell it and I'll sell you mine for $7k.
Bump.
As I have to keep saying to people, the reasons for sale are genuine. I do have a skyline now, I can show you that too if you come look at S12.
I am not into street racing so yes, the S12 is much faster, but I would prefer to own the skyline at this stage... I thought alot of people would understand that... its ok though, if you don't believe me, come for a ride in both. :laugh:
I can vouch for this car. I have been in it at eastern creek during a drift day and I can say it is a very fast and very well set up car for drift. the guy who built it knows what he is doing and the car is not dodge in the slightest.
really nice tight little car. perfect for getting into drifting...
Hey, so is this an N/A SR20 with the Turbo added on?
Yeah its a NA block, with a turbo head. So it does have the injectors of the turbo. The higher compression means you don't feel the lag very much. Please see my dyno sheet and first post if you are wonder how the car was built and with what.
cheers mate.
Yeah the guy that did all the work really knows what he is doing and only sold it to start another project, which is also coming along very well.
the car is much more similar to my old R32 GTR (which had coilovers) to drive than I would have expected. Alot quicker and better handling than my R33 GTSt.
  • 3 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
