I have a 320km Nismo cluster to suit a 33GTR and matching 3 centre gauges.
Looking to sell on exchange basis only, if you don't have stock cluster and centre gauges no deal.
Looking for $500 for both exchange.
Edited by wrxhoon
https://www.sau.com.au/forums/topic/119994-sold/
I was going to put some pics up but i already sold them pending payment on the weekend .
If it falls through i'll let you guys know, thanks for the interest.
https://www.sau.com.au/forums/topic/119994-sold/#findComment-2212682
