gidday.
im looking for a place in victoria (preferably near the frankston area, or a place easilly accecable by public transport...but anywhere really) that specialises in Jap cars to do an apprenticship with.
sent an email to Apprenticships victoria still no reply (sending another one soon).
im going to give various performance places that are listed here a call when i have the time.
anyone who knows anything about the above issue: if you could be so kind to pm me.
thanks all. James.
https://www.sau.com.au/forums/topic/120296-apprenticeship-hunting/
yeah. ive sent out some letters with attatched resume's to a couple of different performance places, but english was never a strong subject so they might read the letter and laugh :)
btw lebostyles: i sent a letter to hypertech, hopefully i'll get a response. thanks for the linky! :P
mulkers: good luck to you mate.
tracid: thinking that will be the way i go about it.
no response to a few places that i sent an letter to, however its only been a few days.
theres an ultra tune near my hood that i have a good relationship with, so ill probably inquire there.
thanks guys. james.
Best bet is to talk to people you know.
My parents are on good terms with a few mechanics, and salespersons, and they were happy to help me out.
Also, registering with a job network like workways or cvgt or something can help a lot.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
