Up for sale is my lrx.500 guys. This amp has not seen more than a months power, it was running my Boston Z6's with the gains turned down. My splits absolutely sang when run off this amp. If anyone knows anything about car audio, they'll have heard of Audison and the pure SQ that comes from these amplifiers.
Some quick specs:
2 x 200wrms (4 ohm)
2 x 330wrms (2 ohm)
1 x 660wrms (4 ohm)
Taken from the Audison site:
'Extremely small size, extraordinary musical performances, exceptional energy reserve. LRx 2.500 amplifiers have very high current supply capacity to easily drive even the most difficult loads and thrilling power, for all needs. If used alone, they are especially suitable to handle exacting, good quality speakers systems; if employed in several units, they are the best to build multi-amplification systems with very high SPL values. They have a double bypass Hi/Lo-Pass Butterworth crossover for driving multiamplified or subwoofer systems.'
I'm selling because im in need of some go fast bits.
Looking at $550 plus postage or will swap for anything that i need...
Musky :D
Edited by Musky
https://www.sau.com.au/forums/topic/120545-fs-audison-lrx2500/
BOV, bosch 040 fuel pump, z32 afm, spark plugs, electronic boost control....
Will also consider swaps for wheels or coilovers plus obvious cash adjustment.
All this is for R33 :)
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
