In my r30 skyline. i was driving along the other night and randomly the following lights came on and occacionaly flick off for a second but then come back on.
If the car is under 1000rpm they dont come on, they once I rev it they come on and stay on. Sometimes go off for a sec when i stop or turn.
The lights are:
Door open Light, Coolant Overflow bottle light, Fog lights light, Window washer light, fuel light, and the spare tire light which is not on the dash but next to the interior lights on the roof.
PLEASE HELP!
From George
https://www.sau.com.au/forums/topic/121925-dash-lights-on-help/
hey george
had this problem before i think, all the lights come on right? my car had the door open, coolant overflow, overheated, window washer etc etc.
took it to an auto electrician, turned out to be buggered alternator or something. $200-odd dollars i think it was (i'm located in perth though).
Its kinda tough how much it SHOULD cost, cos i have nothing to compare it against (if anyone's had it cheaper, forum whore's had the same problem and fixed it for half the price, etc etc).
Good luck with the fix :)
hey george
Repco has alternators for under $200. So i'll go get one from there.
yep sounds like a charging problem. could be as simple as the fan belt loose/slipping, or wire fallen off the back of the alternator. Or it could be the alternator itself, but it pays to chack the basics first. Normally in the Bosch type alternators, its just worn brushes. These are replaceable without removing the alternator, and will cost alot less than a reco/exchange alt. If it turns out you need a replacement alt, I'd get one from a auto sparky. They're normally cheaper than repco in my experience.
can anyone tell me what the 2 warning lights on the R30 dash that look like headlights mean? There are 2 of them, one faces left, and right next to it the other faces right. I intermittently get the one on the right lighting up when the headlights are on. What the hell are they?
Edited by hrd-hr30
In the top l/h corner. Twoheadlights. The one on the left is blue for hi beam, the other comes on when you brake then goes out. If it on all the time you have a blown globe some where.
doesnt come on or go out when i break. it does nothing until now
thanks. all the lights were working. It's only on intermittently when the lights are on, half the time its not lit up at all, and it flickers at times too. Maybe I should check for a loose wiring at one of the lights...
I think all the lights on is an altenator problem. Been there done that.
The two head lights on the dash are, as I said, blue for hi beam. The other on the right of the blue comes on to signify that you are braking and the brake lights are working. No braking, no light. If the light is on all the time even if the headlights are not in use it means you have a blown globe in the stop light system. In 23 years of owning my RMR30, the only globes i've had to replace are three l/h stop light globes.
Hope this helps.
Hope this helps.
sorry about confusing the issue. I agre if all the lights are on, its a charging problem. That was happening when my fanbelt was slipping when i first got the car.
aha - I did have a stop light out! all fixed now! why does it look like a headlight if its a stop light??? now if it looked like a stovetop hotplate I would've got it... :thumbsup:
  • 3 weeks later...
yep sounds like the alternators not doing its job as well as it should. if its not that, try whacking the dashboard. could be a loose connection.
i changed the alternator and its still happening......
Is it like you first mentioned? If so I suggest you get a propper diagnostic checkup.
The only time I had a heap of lights on the dash was when the altenator shit itself. I got it fixed and bugger me it did it again. Turned out the "new" altenator was faulty.
How should I go with diagnosing a fault like this?
If the problem is still ther you will have to get a GOOD auto electrician with all the diagnostic gear. Try the Yellow Pages
Pitstop Books in Perth have manuals for R30 if you need one. About $100 but a must have. I got one last year and it has saved me heaps.
Does it have anything on the FJ20 in it
no ti doesnt. and i got a r30 manual for $3 last year. But how is taht going to help me fix this? there is no fault in here to do with whats happening to my vehicle.
SERIOUSLY! I'm sure someone here can help. half of you seem to be extremely knowledgable. PLEASE HELP!
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
