In my r30 skyline. i was driving along the other night and randomly the following lights came on and occacionaly flick off for a second but then come back on.
If the car is under 1000rpm they dont come on, they once I rev it they come on and stay on. Sometimes go off for a sec when i stop or turn.
The lights are:
Door open Light, Coolant Overflow bottle light, Fog lights light, Window washer light, fuel light, and the spare tire light which is not on the dash but next to the interior lights on the roof.
PLEASE HELP!
From George
https://www.sau.com.au/forums/topic/121925-dash-lights-on-help/
hey george
had this problem before i think, all the lights come on right? my car had the door open, coolant overflow, overheated, window washer etc etc.
took it to an auto electrician, turned out to be buggered alternator or something. $200-odd dollars i think it was (i'm located in perth though).
Its kinda tough how much it SHOULD cost, cos i have nothing to compare it against (if anyone's had it cheaper, forum whore's had the same problem and fixed it for half the price, etc etc).
Good luck with the fix :)
hey george
Repco has alternators for under $200. So i'll go get one from there.
yep sounds like a charging problem. could be as simple as the fan belt loose/slipping, or wire fallen off the back of the alternator. Or it could be the alternator itself, but it pays to chack the basics first. Normally in the Bosch type alternators, its just worn brushes. These are replaceable without removing the alternator, and will cost alot less than a reco/exchange alt. If it turns out you need a replacement alt, I'd get one from a auto sparky. They're normally cheaper than repco in my experience.
can anyone tell me what the 2 warning lights on the R30 dash that look like headlights mean? There are 2 of them, one faces left, and right next to it the other faces right. I intermittently get the one on the right lighting up when the headlights are on. What the hell are they?
Edited by hrd-hr30
In the top l/h corner. Twoheadlights. The one on the left is blue for hi beam, the other comes on when you brake then goes out. If it on all the time you have a blown globe some where.
doesnt come on or go out when i break. it does nothing until now
thanks. all the lights were working. It's only on intermittently when the lights are on, half the time its not lit up at all, and it flickers at times too. Maybe I should check for a loose wiring at one of the lights...
I think all the lights on is an altenator problem. Been there done that.
The two head lights on the dash are, as I said, blue for hi beam. The other on the right of the blue comes on to signify that you are braking and the brake lights are working. No braking, no light. If the light is on all the time even if the headlights are not in use it means you have a blown globe in the stop light system. In 23 years of owning my RMR30, the only globes i've had to replace are three l/h stop light globes.
Hope this helps.
Hope this helps.
sorry about confusing the issue. I agre if all the lights are on, its a charging problem. That was happening when my fanbelt was slipping when i first got the car.
aha - I did have a stop light out! all fixed now! why does it look like a headlight if its a stop light??? now if it looked like a stovetop hotplate I would've got it... :thumbsup:
  • 3 weeks later...
yep sounds like the alternators not doing its job as well as it should. if its not that, try whacking the dashboard. could be a loose connection.
i changed the alternator and its still happening......
Is it like you first mentioned? If so I suggest you get a propper diagnostic checkup.
The only time I had a heap of lights on the dash was when the altenator shit itself. I got it fixed and bugger me it did it again. Turned out the "new" altenator was faulty.
How should I go with diagnosing a fault like this?
If the problem is still ther you will have to get a GOOD auto electrician with all the diagnostic gear. Try the Yellow Pages
Pitstop Books in Perth have manuals for R30 if you need one. About $100 but a must have. I got one last year and it has saved me heaps.
Does it have anything on the FJ20 in it
no ti doesnt. and i got a r30 manual for $3 last year. But how is taht going to help me fix this? there is no fault in here to do with whats happening to my vehicle.
SERIOUSLY! I'm sure someone here can help. half of you seem to be extremely knowledgable. PLEASE HELP!
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
