Apexi PoweFC - Ljetro VS Djetro
For some time this debate has gone on with various opinions and ideas with no real concrete evidence/proof or logic to back it up.
There are two distinct differences between the LJetro and Djetro PowerFC (and presumbably other LJetro/Djetro ECU's) and we will discuss them as this is a hot topic.
Having since worked out the mathematics behind the Load axis calculations for both the Ljetro and Djetro versions of the PowerFC I can show you how they are both calculated.
First we should look at each base model and how it works;
Apexi PowerFC Ljetro Version
Uses standard airflow meter
20x20 Load Map
Other addtional supported airflow meters (selectable on menu)
Apexi PowerFC Djetro Version
Uses optional supplied Apexi Map sensor
20x20 Load Map
Other addtional supported map sensors (selectable on menu with correct voltage and offset)
Both units are scalable upto 1100bhp with supported modifications, sensors, injectors etc.
i suspect the ljetro version was created first, and then Apexi following demand added the Djetro version for some select cars as they found customers were migrating to other ECU's to map sensor support.
Ljetro Vs Djetro Load Axis:
Both have arbitary values for Load indiciation, Djetro has higher RPM as its from RB26 Djetro
Airflow Meter Ramp:
Voltage Ramp for Airflow meter load signal. Infinitely scalable, as we can rescale any given airflow meter.
The most commoin airflow meters are supported out of the box, Z32, Q45 and Apexi Power Intake.
Seemingly all the Apexi Power Intake does it alter the ramp values, which should yield slightly higher airflow load values, which should drop them on the map 1.3rows if that, ever so slightly.
Map Sensor Ramp:
Voltage Ramp for Map Sensor. Each sensor has a single Offset and nothing more. Fixed offset value
Optional Map Sensors include GM5bar map sensor and Denso unit's also. The Apexi one is in fact a Denso unit. The only map sensor supported out of the box is the optional Apexi one (denso rebadged).
GM 5 bar and other sensors need their scale and offset placed into the PowerFC to work.
Apexi Ljetro Load Calculation:
LOAD = CORRECTION * (16384 * Airflow lookup(MAFSV) / RPM)
Airflow is proportional to RPM so this is why we are divisible by RPM.
We obtain MAFSV from our running environment.
We lookup the Airflow value from the Airflow ramp table (viewable by datalogit) and use this value.
We lookup the CORRECTION value from the Airflow corretion table, for 4.48v and higher my correction is 84%
See ljetro-data.txt
LOAD = 0.84 * (16384 * 3598 / 4950)
The answer gives us 10003.57 and we can see for load point 14 we have an Load value of 9642.
The load value for point 15 is 11571 so we place our load axis on 14 with a value of 10003
As we can see here the load will always increase as the engine speed increases.
More and more air comes into the system and thus airflow load will always keep increasing until redline.
There have been doubts over this as many people see bog stockish R33 GTST's drop to load points 15 and shoot across.
This is due to the fact they are maxing our the airflow meter at 5.10 or very close to.
The reason it drops to load point 15 is because the majority of them have airflow % correction somewhere near 80% for 4.48v and higher.
Apexi Djetro Load Calculation:
LOAD = Map Sensor Offset * Map Sensor(PIMV)
We lookup the Map sensor offset and use this value (viewable by datalogit).
We obtain PIMV from our running environment
See djetro-data.txt
LOAD = 3289 * 1.95
The answer gives us 6413 and we can see for load point 8 we have an Load value of 5938.
The load value for point 9 is 11571 so we place our load axis on 14 with a value of 6681.
As we can see once pressure is fixed or doesn't increase any more, the load value doesn't.
This will result in a horizontal shoot across method once target boost pressure is reached.
This is because the Djetro version uses air pressure and runs a guesstimation method to calculate airflow.
As the engine speed increases more and more air comes into the system, pressure remains the same and the load axis remains the same.
The Djetro has two additional features which are;
IGN vs TPS correction
INJ vs TPS correction
These are there presumably to assist in correction for the throttle position sensor.
These will have an affect on the output figures but don't appear to adjust the load bearing.
These are much like Airtemp correction or water temp correction, they affect values but don't adjust load bearing.
So that's it in summary, a few myths cleared up. Im glad to have finally worked it out.
ljetro_data.txt
djetro_data.txt
https://www.sau.com.au/forums/topic/122642-apexi-powefc-ljetro-vs-djetro/
I've done a quick pro's and con's of each (my comments are marked as PR). These are the most debated ones
Ljetro
Pro's
-> Out of the box, works great, plug and play nothing more to add/change
PR: This is suitable for the majority of customers
-> Supports factory airflow meters and larger models
PR: This is suitable for the majority of customers and tuners (less fiddling the better)
Cons'
-> Some tuners/owners believe the airflow meter is a restriction
PR: Turbocharged cars have a restriction after the compressor outlet, not before.
-> Once you max out the airflow meter it can't show any more useful load to the ECU
PR: Once you max out a given airflow meter, move to a larger unit with higher resolution.
If you stay with an airflow meter maxing out (stockish GTST customers) then you basically have the same
load bearing as Djetro customers. Once you peak or reach max airflow (the most the AFM can show) then Load doesn't increase anymore.
This is dead obvious for stockish GTST customers who do a map trace.
Djetro
Pro's
-> No air intake restriction
-> No airflow meters in pipework
PR: This can be helpful for large twin applications. It may also help avoid chuffing or compressor shuffling.
With correct pipework and bends you should be able to run twin MAF's or even a big single MAF relocated in the after FMIC pipework
-> Can't max out airflow meters
PR: This is a valid Pro. But once you max out any airflow meter simply change to a larger unit or more scalable unit.
Con's
-> You loose load point resolution once you reach target boost (horizonatal shoot across, as pressure never changes)
PR: This would be my main caveat of moving to map sensor system, the lack of tuning points, as the map isnt a 20x20 useable map anymore.
i have no clue in any of this pretty much, so i cant argue or agree... but speaking from a practical point of view hehe wouldnt it be better to dyno test them both for 2 seconds and then you'd have a definite answer as oposed to the answer on paper ???
there is nothing to prove here. all the information is in what i have posted and how the load axis calculations are different from the normal and djetro versions.
do you honestnyl think if i change my PFC to a djetro version i would magically make another 20rwkw on my 194rwkw gtst? of course not.
this thread simply puts down the exact method used for load axis calculation. there is no 3rd dimension for the djetor load axis. even I thought TPS was the 3rd dimension, but its not.
interesting read paul. good work
(where did you get all the data from?)
we've talked about MAP verses AFM alot recently
though i don't really think the argument of "loose load point resolution when reached target boost" plays that much importance in the scheme of things. For 3 reasons
1- I've noticed when running map traces that the stock ecu is reading more or less from the same load column when at full boost, so just becuase the load *can* show differences in air flow at full boost, it doesn't really need to (because load cell doesn't change with afm reading anyway)
2- Keep in mind at full boost, even if load axis won't change, RPM axis still changes, so the progression in cells across the rev range allows you to make adjustments under these conditions.
The only time this would present a problem is when holding a constant RPM and load is changing, I can't really think of a situation where this might matter unless say, you select 5th instead of 3rd and car takes a while to build up revs
and lastly
3 - Motec and other top ecu's use MAP as the primary load sensor. Infact Power fc's are the only ecu's i can think of that use afm as standard.
So, my belief is that there is nothing wrong with using an ECU that uses a MAP sensor, (mainly due to reason 3, but I have put some thought into this), and whilst the powerfc is probably one of the best value for money ecu's on the market for all-round performance, there are many others to choose from which are better (though mightn't be as easy to install)
And on another note, noone has any hard evidence that MAP sensors are bad anyway, it's getting a little annoying seeing all this anti-MAP stuff going around!!!
Edited by MerlinTheHapyPig
i find that the djetro version will be more fiddly to tune as it won't compensate for climate changes as much as an AFM version would....e.g on a cold night your afm will show increase in voltage as the cooling of the hot wire is greater.....on a map ECU this is probably why most import tuners are mucking around with the tune between drag runs. For a street car i'd go maf and for a race spec car i'd go map.
Edited by brn8r
map sensor tuning becomes more difficult on multiple throttle bodied engines such as the Rb26 and the SR20 GTIR version as they have individual throttle bodies.
the djetro doesn't utilise an extra air temp sensor. the RB26 has a factory air temp sensor in the plenum for air temp correction, but this won't affect load placement on the load map.
on my R33 when i hit target boost in 3rd gear just near 3000rpm my AFM reads 3100mv and slowly increses to 5100mv just near 6000rpm. so for the AFM vesion the load keeps increasing until we peak the engine's efficiency near 6 grand. on the map sensor version my load would have remained static from 3000rpm until redline as the air pressure would have never changed.
I know that, my point is, who cares? revs are still increasing, so your ecu is still progressing through cells on the map.
Sure, there are more areas on the map where you can "theoretically" use at max boost with an afm based computer, but the real question is, do you actually need them?
I haven't seen anyone on this forum post any hard data that demonstrates this is a problem. And the fact that many aftermarket ECU's use MAP sensors, obviously demonstrate that the designers of the ECU don't see this as a problem!!
this point of this thread wasn't to prove anyone right or wrong. it was merely to clear up a few myths and post up the actual mathematics behind it.
ive often wondered why most stockish gtst only max near load point 15 and ive also often wondered how you strectch or bend the afm load points, now we know, use the load ramp table and rescale, which in turn affects the final load bearing
all apexi powerfc's use the airtemp for airtemp correction, that is
IGN correction for airtemp
INJ correction for airtemp
this applies for ljetro and djetro versions (and pro).
they influence more or less IGN/INJ for given airtemp values but won't affect load axis placement.
the R33 GTST is one of the only PFC's to have broken airtemp implementation, that is the factory car does not come with an airtemp sensor so it doesn't work. SW20 customers can purchase an additional sensor and connect it up to the PFC loom for working air temp sensor support depsite the car not having a factory air temp sensor
most ecu's will allow you to change the load and rpm points (stock ecu can do this)
Here is the equivalent of a "map trace" on a powerfc for my car (i think this was third gear but may have been second). This is with the stock ecu, standard tune, standard boost, fairly stock r32 gtst
http://i2.photobucket.com/albums/y19/merli...o/tim_dyno1.jpg <- dyno with boost
anyway, i've found, most of the work is done in load point 11-12 and it tends to stay in the same load point for the rpm range that matters (2,800-6,400 rpm it's in the same load band). In fact, it's interesting that the stock ecu has the load points more spaced out higher in the "load" axis.
Anyway, what i've interpreted from these results are that under high-load conditions the "load axis" is less important than rpm (because it's remains in the same column anyway, even using an AFM)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
