HKS cam pulley intake side like new only been on the car for about 4 week.
$220.
How about $150 delivered? You cen get these brand new from nengun for $186 delivered.
https://www.sau.com.au/forums/topic/123989-hks-cam-pulley/#findComment-2289576
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
