I only smoke when my car is cold.
But, if you have some smoke, how long has it been happening? If you have worked on it recently, it'd be grease or oil burning off as it gets hot. Even a dirty hand on a dump pipe can make a noticeable amount of smoke when the engine is hot.
Is the image supposed to be related in any way?
hi there the image is just of my mate sticking his head in the way as i was fitting my FMIC ,as far as i know its only started to happen about 6 weeks ago ,it doesnt blow any smoke at all and runs good on start up when cold but after running for a while and i stop then hop back into car and start it up it doesnt want to start straight away when it does a puff of smoke comes out of the exhaust and thats it ,you can rev it up and get none ,it idles good and has full boost ,only owned the car for about 5 months if that really happy as its my first r32 but its only an auto but breaks traction in first three gears which i thought was bloody good so im bit concerned about this i dont drive it very hard at all as it has new tyres etc
Ah! Different story! I thought you had smoke in the engine bay or something... so that pic is completely unrelated in every way to the question. =-p
Ditto to Green s13... I wouldn't worry about that. You'd get plenty of that if you back off at high revs. Exhaust soot, basically.
what colour is the smoke, you say it doesn't start straight away if the smoke is black then it is just unburnt fuel from trying to kick over
smoke colour is bluey white only comes out ater its been run then turned off for a while then started then puff out it comes thats why i thought it mite be valve seals like oil getting into engine when warm then it gets burnt when started also in the last week or two ive notice black bits like soot on my back bar after given it a gut full on the way home from work
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
