ppl i have three auto meter white face phantom guages with silver cups come with senders
oil pressure
water temp
fuel pressure
look good in any car done need them
300 plus postage bargain im in mildura vic 3500
Edited by teazn_r33
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
