Thermostatic Cooler Kits, Single/dual Filter Relocation Kits
  • Replies 125
Posted Images
Would it be possible to incorporate braided houses into this.
Say I puchase the core, relocator and thermostat and then supply my own hoses at a later date?
What I am getting at is: are the relocator, fittings on the cooler and thermostat able to take the screw in ends on braided hoses?
very interested.. will hopefully have some money freed up in a couple of months
No worries
Yep, not a problem, they will fit
Does any one have these fitted to their car?
I will def be in as soon as i have cash, thank god for the long time frame gb lol.
Will i need a high volume oil pump because of the relo kit the oil filter will not be next to the block? So will the oil reach the filters no worries if i have the relo kit on the firewall or strut tower for example?
If i was to go for the smaller oil cooler core (polished core) that you posted a pic of will it still cool fine for street applications as i also believe that the other core will be too big for my use and to try and find space in the engine bay for it lol.
Cheers Simon
so if i bought a dual filter relocator, a thermostat, and a oil cooler core, everything that is needed for installation would come with it? or would i need to get hoses made up?
Everything comes that you need to install
Cheers Simon
Hi Simon,
You wont need a hi flow oil pump(such as N1 etc). As the thermostat stays closed, while its cold and only opens when its hot. so meaning the oil is much thinner when its warm, rather then cold. the stock oil pump fill flow fine - even with it mounted many feet away from the filter base/block it self
just another really simple question (that is probably so simple it's stupid, but it's something that's been bugging me for a while)
when you do an oil change - how do you get the old oil out of the cooler core/lines?
You undo the filter, undo the sump plug, let it drain for ages, then if you want to, undo the fittings on the core and allow whats in there to drain back to the block, and then that will end up going out the sump, if you are really keen on getting every last bit out, undo the core and tip it up - but it doesnt hold enough oil to really justify that IMO
Thanks for that..
sorry to be a pain with all the questions, but does the sandwich plate for the relocator have any bungs in it for sensors (i.e. oil temp and oil pressure sensors)?
i'm just trying to cover all the little things that people seem to want to know about, judging by previous threads :D
Thanks for that..
Theres nothing wrong with asking questions :D
Can get a plate with gauge inputs if required but they made in Cchina and i dont want them to be included in to the kit as they are prone to cranking and leaking
For the people who have paid - your kits are in the mail as of yesterday, and i know one arrived today at its destination thanks to express post
defintately interested in this. count me in on one within 2 months.
definately.
hip hip hozar for the long gb period!
cheers. james.
definately.
cheers. james.
Hahaha no worries mate
Yeah made it long so everyone could have a chance :banana:
Subscribe- I have to check my oil cooler kit first (got it last friday but havent opened it up)
More so interested in the thermostat. What size Barbed fittings does it have?
Can it be supplied with a 70-75 deg spring? Or can it be adjusted to open a little earlier?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
