how you going guys,
since ive had my skyline ive had a little bit of problems with idle missfiring i can still here little noises inside the motor under load (TING TING TING not misfiring nor pinging) blah blah, ive fix most of it with the power fc but since the motor is old i was thinking of doing a basic rebuilding mahcining rings polish a few things to it i know its alot of work but what do you all this would it do the RB25 any good?
cheers
https://www.sau.com.au/forums/topic/126740-r33-rebuild/
hey bud, im in the process of rebuilding mine atm, putting in forged pistons, metal head gasket new race bearings and a gasket kit and thats it, just boring the block out too. if you want a basic rebuild thats all you have to do really. should make over 300kw no worries with my gt3040.
https://www.sau.com.au/forums/topic/126740-r33-rebuild/#findComment-2340891
^^that's pretty much what I did when it was rebuild time (bar the metal head gasket, Nissan one is fine IMHO) HOWEVER i do regret not sourcing some GTR rods... I just prepped the stock GTSt rods and stuck them back in there... GTR rods are cheap as chips and will give you peace of mind when your up over 300rwkw and if you want to raise the revlimit above 7000rpm
https://www.sau.com.au/forums/topic/126740-r33-rebuild/#findComment-2340929
What are you two on about?
He is wanting to rebuild because of a mis-fire because its "old"... define old for me :blink:
Dude, no need to rebuild unless the engine is fruited.
Have you done a leak down test yet to confirm there are issues?
If not, then i suggest you do.
No point wasting money, it wont do the motor any good unless the above test tells you there is a problem
https://www.sau.com.au/forums/topic/126740-r33-rebuild/#findComment-2341161
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
