Hi
I am currently in the process of building an engine RB30/26 combo. What I have discovered is that the only brands apart from the jap brands BIG $$$ is the ARGO and SHALLAK versions which cost around $2,600 a set which is still bloody expensive. I have been in contact with a workshop with a good reputation in builidng race engines and we have decided to see if we can try and get a suitable rod out of whats already available. What I am after the rod length of the followin stock rods:
* RB20DET Rod
* RB25DET Rod
* RB26DETT Rod
*RB30ET Rod
The rod length must be exact and from middle of gugoen pin hole to journal hole. We hope to be able to souce rods good for around 600-700HP for around 800 a set even a bit more will be worth it compare to 2,600 for the aussie ones and 4,000 for the jap ones.
GR8NES
  • Replies 53
Yes, up until recently they haven't been making them, but I believe they are now available. Previously the US market has only been after rods for SR20's and VG30's, but now Skylines are starting to become more popular Eagle has decided to make rods for them to.
See'ya:burnout:
Hi guys, if you check the measurements of the standard rods you will find that they are very, very close to the sizes of some very, very common conrods that you can buy, off the shelf from a large number of suppliers. No they aren't made for Nissan's, something much more common in the home of good conrods.
Don't fall into the trap of matching the little end to the standard Nissan gudgeon pin. Aftermarket pistons have the "right size" gudgeon. And remember that Nissan have a variety of big end bearing thicknesses, so you can make minor corrections in the big end journal dimensions as well.
I am looking forward to having this data in the public domain, so good hunting................
Try cunningham rods in the states they do anything rod sizes and they are mega serious rod. they have special patent design and are suppliers to alot of the lemans team. so they can't be that bad. also i think mine cost under 2k
I have found out what rods can be used, they will require very small modifications and they are good for around 700-800HP and cost around $899. The pistons used are RB30 pistons with the pin size to mach the rods. Sydneykid am I getting close????
GR8NES
How's your venture with the rods going?
I'm interested to know as well cos i have an RB30 block and crank sitting in the garage doing nothing... i don't have rods or pistons so i also need to know what specs i need!
Cheers,
Andrew
I learnt that the V8 Chevy Small block 6" Small Journal rods can be machined to fit, I am still deciding which path to take since they are rated at 800HP for eight, then that makes 100 per rod which in an RB means 600HP at the flywheel, I am aiming for closr to that at the wheels, I am able to get a set of RB30 Carrillo Rods for 2,400 which will take 800HP and 9000rpm quite easy. Unless someone else has used the SCAT, Eagle or equivalent rods with success at say 600HP at the wheels with proof I might bite the bullet and go the Carrillos.
GR8NES
yeah $2400 for rods seems HEAPS!!!
i'm looking for around 300rwkw, but would like to build the engine to cope with 600hp at the wheels as well incase further down the track i decide to upgrade the gearbox and go for big power!
are the chevy rods fully prepped, eg forged/linished/shotpeened or what ever is done to make strong rods?
cos maybe you could get those rods and have them strengthened further... like chryotuff :P
Well they are fully prepped and Cryo Tuff may strengthen them further but not sure. 2400 is cheap for Carillos ARGO's are around the same money and NIZPRO quote $3600 for Carrillos they are the best you can get for a street engine. May be if we ask for two or more sets we can get a discount ????
GR8NES
sounds good to me!
$2400 is fairly pricy, especially as i'm not going for 600hp at the wheels... what do you reckon the chances are of getting them under $2k? :P
maybe those chevy ones will tie me over till i need more power, then i can pull out the rods and put in better ones. Then there's the other side of the coin. $900 for the chev ones or $2400 for the carrillo ones, it's gonna cost me $1500 to do the change over down the track anyway, even if i do most of the work myself!
600hp at the engine... what would that translate into rwhp?
GR8NES
GR8NES, can you confirm that the rods to suit an RB25 are 6"? What are the exact dimensions. Also what Chev block is it that uses these rods that are the same size as the RB ones? Sorry, these are alot of questions, but if one company makes them (chev rods) - alot of companies will make them, and from what sydneykid was hinting at, I will bet that there is a company out there that makes the right size, at the right hp rating, and the right price - just not under the nissan tag.
Sorry there are a few questions here, but I wouldnt mind doing a bit more research myself and then post up any results for all to share
Cheers
Steve
Just did a bit more research after asking those questions. Chev 6" rods are used on the 350 and 400 - are these the ones we are talking about GR8NES? Cos if so, I will shoot an e-mail off to carillo and get the low down on the rating per rod, and the cost.
Cheers
Steve
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
