Howdy Gals & Guys.
I have a very interesting issue, my 4WD light comes on intermittantly.
I have a 97 Stagea RS Four V which has been converted to Manual and has a Power-FC put into it, amoungst other bits and pieces.
Anyway All the work was done before I bought the vehicle. Bought it about a year ago.
Now it has been bloody awesome, except as the weather has gone colder and colder I notice that if I give it a squirt when the weather is cold, the 4WD light does go on and I do go into RWD mode, which is worries me a bit.
I have checked the fluid level in the ATTESSA system (in the rear) and checked all the fuses, all look fine......?
No here is the funny thing, if I leave the car in sunlight for 2-3 hours and make sure that the passenger rear section is in the direct sunlight, (where the ATTESSA ECU is), I dont have this issue... wierd eh.
So what i am thinking is that the ATTESSA ECU doesnt like being cold..... WTF?!?!?! That cant be right!
So did a search but cant really find any threads that help out so anyone have any ideas what it could be?
Thanks!
Cy
https://www.sau.com.au/forums/topic/127100-4wd-light-on-dash/
When any circuit board gets a bit older, the tracks can form very small cracks. These tracks stop the flow through the cracked track. When the circuit is heated the tracks expand, in turn closing the cracks and therefore making the circuit work again. I dought that this is your problem as it generally only happens to much older circuits, but if your can has been heated and cooled a lot, this constant expantion and contraction of the tracks could form these cracks, say if it stands in the sun a lot in the day and then gets really cold at night.
Maybe just another avenue to look down, good luck.
P.S you will need a magnifying glass to see these cracks
Cool sounds plausable, just didnt think it was that probable! The car does sit out in the sun in the summer time and it does get cold at night, as it is only in a carport, not garaged, but still only gets done to ~10oC overnight, so might be it.
I dont intend on ripping out nearly the entire rear section f my car just to get to the ATTESSA system if I dont have to. I wouldnt even know what to look for anyway :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
