damn thats mad i want one, does anyone know where i could get one? prefer the mines version rather than the plain autech if possible.
good find mike >_<
no secrets here hey that dam nick of mine is everywhere :whistling:
https://www.sau.com.au/forums/topic/127942-looky-looky/#findComment-2365731
lol most definately!
green is the only colour available, there is also another one that has something on the roof racks and its a different shade of green, but it sells for a lot more than the plain green one.
https://www.sau.com.au/forums/topic/127942-looky-looky/#findComment-2371718
Actually, they made them in white too :P
TOMICA No. 82, but mine was a key ring to start off with. Got to get around to removing that ring from it. Had to buy a white one personally, with my stagea being white. Might tint the windows with that tint paint i bought for the model... which i also sprayed white... its all a working project. :D
Check out that front negative camber!
https://www.sau.com.au/forums/topic/127942-looky-looky/#findComment-2372578
Actually, they made them in white too :D
TOMICA No. 82, but mine was a key ring to start off with. Got to get around to removing that ring from it. Had to buy a white one personally, with my stagea being white. Might tint the windows with that tint paint i bought for the model... which i also sprayed white... its all a working project. ;)
i remember seeing the white keyring one when i bought mine, but i cant find them anymore
https://www.sau.com.au/forums/topic/127942-looky-looky/#findComment-2374039
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
