Yeah I can, but a few guys can get really good prices on RE540's, so wait to see who else responds.
True the 4WD helps at the plex, but they aren't desinged for drag racing, but one of the best for dry road and track, ask Ken what there like in the wet.
See'ya:burnout:
the 540's are a good compound. Get them in a taller profile for better sidewall flex and I'm sure they will prove to be an excellent choice for the drags.
35 profile is a little low 50/55's are better. also if you can match the rim width to tyre width thats the way to go for retaining some good handling (on that topic I'm sure gtrken is the guy to chat to).
Guest KILLER-T
Hi ya Brett if you are buyin the re540s for the drags then dont bother the side walls are way to hard to get any advantage from them on the 1/4 mile but for a track tyre they would be great.I cant tell you what they are like in the wet but on a dry road the are the best thing i have used.The only thing i dont like about them is the amount of road noise they make
but thats for drags, and you dont drive to work in 1/4 mile stretches. id go for an all-round tyre which performs on the street, if your keen on making good times at kwinana get a couple of stock rims with higher profile tyres
plus being 4WD you dont have to worry as much as us RWD guys cos traction is aided by atesa
Originally posted by EVL R33
Anybody using these tyres???  Comments on wear rates and performance in both wet and dry???
Oh,  anyone using Pirrelli PZero NERO's??  Comments??
Cheers
Brett
Its all i use now days on my car, using them for normal street punting feel a lot safer due to the extra grip..
anyway, as a track tyre, there fantastic, for the drags as everyone has pointed out, they arn't so flash, but if your serious about the drags, buy slicks, simple..
As for wear, how long is a piece of string, i usually get around 6 months a set, street driving and a pile of events, for normal street driving you'd probally get 20 thousand out of them, but it depends on how you treat them, and thew downside to street driving is with the heat cycles they get hard, my last set after there 6 month tour of duty where tops for drifting a 4wd, not so hot for grip when i wanted it..
So there not that good a daily if you want to hammer them at the same time..
usually a better idea to keep them on a second set of rims, and swap them over when you need them..
The tyres I use at the drags are the ones I drive home on and do 35,000+kms on a year.
50 even 60 profile tyres are fine for going around corners on a street car. They offer even better ride comfort, something that is often needed when you have concrete coil overs.
There is bugger all radial roll on a good set of tyres like the re540s even at this profile.My old toyo proxes were 55's as well and had no radial roll at all.
To combat the hardening of the tyres from street use over time you can occasionally apply some AZNU tyre compound on race days (Ozrace stuff) get it from A1 performance I think.
so a 50-60 profile tyre is going to have enough sidewall stiffness when fully inflated that you can push hard through corners on the street and have decent handling (forget comfort) yet when de-pressurised can provide enough sidewall flex to launch well at the drags? seems a little too good to be true
instead of getting a tyre which will do both jobs in a mediocre fashion, if youre really that concerned with 1/4 times get a second pair of tyres. also as i mentioned before sidewall flex isnt as big a concern for 4WD cars compared to 2WD. i understand the sme principles of squatting down to gain max traction apply but less so with the attessa system in place.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
