Yeah I can, but a few guys can get really good prices on RE540's, so wait to see who else responds.
True the 4WD helps at the plex, but they aren't desinged for drag racing, but one of the best for dry road and track, ask Ken what there like in the wet.
See'ya:burnout:
the 540's are a good compound. Get them in a taller profile for better sidewall flex and I'm sure they will prove to be an excellent choice for the drags.
35 profile is a little low 50/55's are better. also if you can match the rim width to tyre width thats the way to go for retaining some good handling (on that topic I'm sure gtrken is the guy to chat to).
Guest KILLER-T
Hi ya Brett if you are buyin the re540s for the drags then dont bother the side walls are way to hard to get any advantage from them on the 1/4 mile but for a track tyre they would be great.I cant tell you what they are like in the wet but on a dry road the are the best thing i have used.The only thing i dont like about them is the amount of road noise they make
but thats for drags, and you dont drive to work in 1/4 mile stretches. id go for an all-round tyre which performs on the street, if your keen on making good times at kwinana get a couple of stock rims with higher profile tyres
plus being 4WD you dont have to worry as much as us RWD guys cos traction is aided by atesa
Originally posted by EVL R33
Anybody using these tyres???  Comments on wear rates and performance in both wet and dry???
Oh,  anyone using Pirrelli PZero NERO's??  Comments??
Cheers
Brett
Its all i use now days on my car, using them for normal street punting feel a lot safer due to the extra grip..
anyway, as a track tyre, there fantastic, for the drags as everyone has pointed out, they arn't so flash, but if your serious about the drags, buy slicks, simple..
As for wear, how long is a piece of string, i usually get around 6 months a set, street driving and a pile of events, for normal street driving you'd probally get 20 thousand out of them, but it depends on how you treat them, and thew downside to street driving is with the heat cycles they get hard, my last set after there 6 month tour of duty where tops for drifting a 4wd, not so hot for grip when i wanted it..
So there not that good a daily if you want to hammer them at the same time..
usually a better idea to keep them on a second set of rims, and swap them over when you need them..
The tyres I use at the drags are the ones I drive home on and do 35,000+kms on a year.
50 even 60 profile tyres are fine for going around corners on a street car. They offer even better ride comfort, something that is often needed when you have concrete coil overs.
There is bugger all radial roll on a good set of tyres like the re540s even at this profile.My old toyo proxes were 55's as well and had no radial roll at all.
To combat the hardening of the tyres from street use over time you can occasionally apply some AZNU tyre compound on race days (Ozrace stuff) get it from A1 performance I think.
so a 50-60 profile tyre is going to have enough sidewall stiffness when fully inflated that you can push hard through corners on the street and have decent handling (forget comfort) yet when de-pressurised can provide enough sidewall flex to launch well at the drags? seems a little too good to be true
instead of getting a tyre which will do both jobs in a mediocre fashion, if youre really that concerned with 1/4 times get a second pair of tyres. also as i mentioned before sidewall flex isnt as big a concern for 4WD cars compared to 2WD. i understand the sme principles of squatting down to gain max traction apply but less so with the attessa system in place.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
