For sale:
Bolt-on turbo kit for Nissan RB20/RB25 engines.
Good for up to 250rwkw with exceptional boost control from the external gate.
Ran 12.9 @ 111mph on RB20DET with computer/FMIC/3" exh/std injectors/15 psi boost
Ideal drift turbo!!
HKS T300 turbo rated at 450hp
0.6a/r T04E style compressor, 3" inlet, 0.63a/r exhaust housing, Braided oil feed line
Tial 38mm wastegate
RB20 cast manifold
Professionally modified to fit wastegate, TIG welded stainless pipes. Will not crack!
Stainless 3" dump pipe
Condition:
All in excellent condition,
Price and price conditions:
$1500ono
Extra Info:
More pics ---> http://www.wave.co.nz/~hksnz/t51rkai.html
Contact Details:
PM or email [email protected]
Launceston TAS
Delivery & Conditions of Delivery:
Can deliver to anywhere in Australia cheaply at buyers expense.
Edited by VHR32
https://www.sau.com.au/forums/topic/128050-withdrawn/
I think it was 4000, I never really checked! Depends which gear you're in. Pulls all the way to 8000.
It is a little bit laggier than a standard RB20 turbo but that is expected because of the bigger exhaust housing.
It made a massive difference in power!
Yes, will fit RB25's too.
https://www.sau.com.au/forums/topic/128050-withdrawn/#findComment-2368354
I have no idea how many kilometers...
No more shaft play than normal.
I didnt make 250rwkw as I have std injectors and a small fuel pump, Would make this with a RB25 and proper fuel system.
They are rated at 440hp.
https://www.sau.com.au/forums/topic/128050-withdrawn/#findComment-2384585
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
