car was defected while a mate was driving and i have since taken it to have the defect cleared, basically was a major defect to be cleared by authorised blue slip place. any ways was for blow off valve, pod, inside of tyres being warn, and also check that exhaust complies to adr standards or whatever - check is not louder then 90dB and car to have full pit inspection, any way i took it to have the exhaust level checked, then took it to a blue slip place they said they were too busy directed it to some body else, the guy i took it to said even tho my exhaust was only 86.3dB he wouldnt clear it because its not standard he said i have to have an engineer check my emissions and do a thingy for me, any way i reckon its a bit bullshit, any one done this before, if the copper wanted my emissions tested would i have not been sent to epa? im yet to take it to another place for a second opinion
https://www.sau.com.au/forums/topic/129013-defect/
they usually send the EPA letter a week or so later. you'll probably get that soon.
as long as your car checked out to be under 90db and you had proof of that when you went to get the blue slip, then there was no reason for them not to pass you.
all you need to do is comply with the standard, not be standard. you might need to explain that part to them.
also, if you get the EPA letter i suggest clearing that before going for the blue slip.
https://www.sau.com.au/forums/topic/129013-defect/#findComment-2386390
A lot of places won't pass an exhaust on a defected car, as it can come back to haunt them. A vehicle really does need to be engineered if it has any modification which can change its emissions.
Having said that, you shouldn't have too many problems passing emissions as long as you have a working cat converter.
The advantage of having an engineers certificate, combined with legal modifications, is that when you get pulled over, you have absolutely nothing to worry about.
https://www.sau.com.au/forums/topic/129013-defect/#findComment-2398104
any ideas on a good engineer who dosnt cost to much?
https://www.sau.com.au/forums/topic/129013-defect/#findComment-2398958
Hey PM me and I can get the bluey done for $100 my mate wont even really be looking at it ok, he is at Cherrybrook area, as long as it looks decent you will be fine, Ill just have to organise a day when i can take you down there if your interested???
https://www.sau.com.au/forums/topic/129013-defect/#findComment-2400823
wow, she came through.. Well done Jayla.. Nemz was telling me how mad you were.. Cheers
Well of course I came through did you expect differently???
Nemz owes me big time lol I went to alot of trouble to help him :0) just joking...
Anytime Nemz your cool...
https://www.sau.com.au/forums/topic/129013-defect/#findComment-2423699
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
