Not another RB26 with a bearing about to spin... It doesn't sound good if it comes from the bottom end.
Was it always like that? If yes it could be lifter noise if it started recently not good news.
https://www.sau.com.au/forums/topic/129221-tap-tap-tap/#findComment-2390211
Hmm im not sure where the sound is coming from really but I will check that later. I just had the engine rebuilt so I dont think that would be the problem of spinning bearings (well i hope not). I can only hear it when im outside but not in the car and I can hear it more when listening from the side.
Edited by PhilGTR
https://www.sau.com.au/forums/topic/129221-tap-tap-tap/#findComment-2390676
If thats the case and they did the job correct its probably lifters, the clearances are to big.
Who ever put the engine together did they check them? If they are not familliar with Rb26's they may have them backwards. In RB26's the inlet clearance is bigger that the exhaust and thats unsual.
https://www.sau.com.au/forums/topic/129221-tap-tap-tap/#findComment-2391202
Well im pretty sure they checked it cuz i remember they had to send the head back to the guy who was doing it to get the clearences right. The guy who rebuilt mine has rebuilt many rb26's including his own... the tapping isnt really loud but i just dont like the sound of it. my engines done about 5000kms now and hope it will be ok, Im going to talk to him about this when i get it serviced with him soon.
Thanks for the input guyz.
https://www.sau.com.au/forums/topic/129221-tap-tap-tap/#findComment-2391461
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
