Ok so i disconnected each coil to narrow it down to a cylinder that was the problem, its no.1.
First thing i did was pull the sparkplug out, looks a bit black, and has that shiney coat i mentioned earlier? Could be fuel??? but had no strong fuel smell to it...
Ran a compression test - 150psi on that cylinder (didn't have time to do the others)
Put in a copper plug, didn't fix it, took out the splitfire coil and replaced it with my standard one, didn't fix it.
So at this stage i'm assuming it has to be a wiring fault to the no.1 coil.
Could be your injector??
Check if your spark plug is actually firing. Take it out, coil and all and earth spark plug on to engine and actually physically check if it firing. (preferably unhook injectors at this time as well as fuel mist could be bad in this test).
Glad to hear your compression is ok! PHEW!!!
Edited by 12DFY
Ok so thought i was stupid to do the compression on only 1 cyl so went back and did the whole thing
No1 150psi
No2 150psi
No3 140psi
No4 140psi
No5 145psi
No6 140psi
no 1 actually gave a reading as high as 160psi but with a couple of repeats the figure was 150psi.
Now i'm really out of time, have to get ready for the drive to the sunny coast.. Stupid work ;)
12DFY- yep i'm suspecting injectors aswell, i'll get someone to check them aswell as the circut to no.1 coil.
if you dont find any problems .. disconect your batt .. leave it out for a hour or so .. this should reset your ECU then start up see if that helps .. hopefully its sorted out soon
If you want , I can plug the laptop in and have a look at any fault codes ,but must be before Friday 1.00pm as we are off to Leyburn for the weekend . Live at Shailer Park and work across the road from home.
Brad
A black spark blug can mean 15 difrent things was it oily or was it dry powdery or was it thick tar like??
Again I will say It sounds like the COMPUTER to me give me a little more info on what the plug
was like * Also it shouldnt smell like petrole in the chamber becouse it burns 0_o lol *
I belive you could probly download a chart on Spark plug discoloration identification and problme solving
as you will notice most work shops have one.
PS: I still think its related to the computer.
PPS: who said it was a head gasket 0_o the noise stoped and started again....
woooo back from the sunny coast,
Took it to moolooabah auto electrics (on aerodrome rd moolooabah) - talked to a kiwi bloke there, left my car for an hour, came back and it was running like a dream!
The fault was traced to the injector - although there was power going to it, the ecu triggers the injector to inject by earthing it - which it wasn't doing- he pulled out the ecu to check for faulty parts, water damage etc- all good- when he put it back in the car ran fine again! I suspect a loose connection either in the pin of no.1 injector earth lead (on the ecu side) or a problem within the ecu itself- maybe dry solder joint?
Either way problem was fixed and only cost $88!! (i was thinking hundreds at least!!)
Excellent mate, good to see it is finally sorted! We were right it was the injector!!!!! Injectors are an absolute pain in the arse of a thing to diagnose. I Had a injector that was working fine but was dribbling constantly, the only symptom it had was blowing heaps of smoke when it was revved. That took me a good few days to find!!!!!
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
