Nissan Skyline E-ECR33 Series II
Condition: excellent
White
Manual
144,000km - (highway k's, I live just out of melbourne)
majority of kilometres done in Australia (Imported in 2000)
Rego 9 months (April 2007)
RWC
Melbourne
Extreamly cared for
Always garaged, (even at uni)
Always driven respectably
Never raced or taken to a track
Very rarely boosted beyond stock
Never been owned by a smoker.
Serviced every 5000k's
All parts fitted by "AVO turbo world" and serviced by "Amberley autos" & "MI Automotive"
Have all receipts
MODS
ENGINE:
*Trust pod
*Blitz blow off valve
*Blitz turbo timer
*Blitz electronic boost controller
*Blitz intercooler
*High flow cat
*Heavy duty clutch
*Apexi muffler
*Apexi SAFC
*Iridium spark plugs
INTERIOR:
*Apexi digital speedo & timer
*Auto Sport boost gage
SUSPENSION:
*Tein coilover adjustable racing suspension
*Strut bars: Apexi (front) and original skyline bar (rear)
*Hicas Lock bar
WHEELS & TYRES:
R*OH 17” X 8.5” Fury wheels (shadow chrome)
*New Pirelli tires (front), 50% tred (rear)
BRAKES:
*DBA 4000 series disks (front)
STEREO (Worth $3000+):
*Focal splits (front)
*Clarion splits (rear)
*2 Crossfire amps
*2 10”Crossfire subs
ALARM:
*Viper alarm system and immobiliser
200rwkw's @ 11psi
Smooth engine, incredible handling
Selling for financial needs
Regretful sale
$16,500 ono
CONTACT: 0402 284 263 (any time except 10am to 1:30pm Fridays)
https://www.sau.com.au/forums/topic/129953-sold/
Guest
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
