  • Replies 40
Posted Images
No mark dont go any lower than 20k..
there is another guy selling hes better than average 32 for 19 and its still runnin a rb20 and only runnin 170rwkw.
If someone gets this car for 20,000 they will relise its worth every dollar spent.
Well i still think u shouldnt sell at all.. cauz if u do it makes the number of skylines boys at beacy pizza 3.
good luck,
kev.
https://www.sau.com.au/forums/topic/130416-sold/page/2/#findComment-2491973
Just wondering were the any legal dramas with the conversion? Did you need and engineers cert? How was insuring it with the new engine? I ask because i would love to do the same thing with a 32.
https://www.sau.com.au/forums/topic/130416-sold/page/2/#findComment-2546447
Thanks Kev :)
Have to catch up soon.
Things were quite simple with the engine conversion.
All I had to do was get a letter from a Nissan Dealership stating
that the RB25 came in the R32 which a select few did and then take the letter to vic roads and they updated their system and sent me a new rego sticker.
I was told that if the motor came out in that model an engineers certificate is not required. Thats why the letter from Nissan was needed to confirm.
Hope that helps :happy:
Mark
https://www.sau.com.au/forums/topic/130416-sold/page/2/#findComment-2547422
Ay mark i hear u put a deposit on that sss.
I cant say im happy but i will have to wait and see..
oh and i was thinking of gettin damo to switch computers with me to see how my car would go with a remap. was thinkin we would probly do at ur house or somethin. so we willhaee to organise something with damo.
anyways see u sat
ciao
https://www.sau.com.au/forums/topic/130416-sold/page/2/#findComment-2555488
Hi Kev,
Yes I will be more than happy to help you try out Damo's remapped Ecu.
Anytime you like I will make the time.
It was remapped by Dr Drift whom is on these forums.
The map is for a basic set up ie. exhaust,cooler bit more boost etc...
From memory its about a 15kw at the wheels gain.
You will like the SSS its a 99 model, metalic blue and very very clean.
Its just what I need something smaller, more practical and economical.
Talk to you soon
Ciao :happy:
https://www.sau.com.au/forums/topic/130416-sold/page/2/#findComment-2555642
Hi Kev,
Talk to you soon
Ciao :happy:
Well i did the exact opposite....from a 2001 pulsar to 96 R33. Petrol might cost a bit more but its so worth it...
https://www.sau.com.au/forums/topic/130416-sold/page/2/#findComment-2555677
Obviously the Skyline is a better car all round, although at
the moment my priorities are different.
I am after something quiet, soft on the road, more economical and
I want to start saving $$$ for a house.
I found a really nice metalic blue pulsar sss which I should be getting
next week hopefully and at least it has an sr20.
:P
https://www.sau.com.au/forums/topic/130416-sold/page/2/#findComment-2559385
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
