Ive noticed over the past few months that about once every say 2 weeks instead of my BOV going off I get massive amounts of flutter, I have an aftermarket Apexi BOV and usually it goes off all the time and I get next to no flutter but on some occasions for about an hour or so it wont go off and I just get massive flutter, the car still runs the exact same performance wise when this happens but I just wanted to know whats going on?
I also have a pod filter and front mount if that contributes to this at all, turbo is stock with 14psi.
Cheers guys.
https://www.sau.com.au/forums/topic/131787-random-flutter/
Your bov is sticking shut or something is jamming it from opening, so instead of it letting the air out its causing it to go back through the turbo and out the intake causing a flutter noise.
This is the noise you would hear if you had no bov at all.
https://www.sau.com.au/forums/topic/131787-random-flutter/#findComment-2441150
    • Out of curiosity, how do officials determine what the OEM ride height and suspension specs are? Do they have a book of truth? I'd think that would be quite obscure knowledge for random JDM cars.
    • This is the check list they sign off on. This implies that adjustable coilovers of the type we're referring to are not a "Variable Ride Height" system. This very much is in the ethos of "I can change the height while moving/while parked without pulling wheels off the car and mechanically doing so"
    • Just an update  ... Put the cat back on no issues with the car running wise ... maybe alittle longer to spoil up the turbo. Still running rich but waiting for my tuner to come back into town to retify the situation. WOT runs fine with the cat.
    • Hi,    Where does everyone buy their stock GTR R32 replacement parts from in Japan preferably? I usually order alot from RHD Japan but sometimes they dont have what I need. Whats the best website for parts in Japan ... as I live in Hong Kong so best ordering from there.    Thanks
    • My post contains the actual truth. Clause 3.2 b.
