Wtb: Clean, Rust Free S12 Shell (hatch) With Irs In Melbourne
As above.
I put my s12 into a wall on Wednesday night. Desperately searching for a shell so i can get back amongst it. Any help finding one would be greatly appreciated.
Cheers,
Nick.
P.S. How's this... if someone finds me a good car which i end up buying, ill chaufuer u and 5 mates for an entire night in my 6 seater 85 Ford LDT stretch limo. (that's gotta be worth over 400 bucks...a limo (with wicked old school attitude :P at your beck and call for a night...)
Edited by cloudbreak
hey mate i know someone who is selling a s12 gazelle for $1200 all it needs id tyres for rwc, new motor plus other stuff if ur interested give me ur number and i'll get him to give u a buzz.
YES!
0409 593 100
Cheers man. Any help appreciated.
Nick.
  • 1 month later...
only just saw this, if you're still after one I have a complete gazelle in exc condition.. shouldn't need anything for RW, it was RW'd not long ago. Engine has been recon'd, runs very well.. new tyres etc.
Let me know if you're still looking for one,
Cheers!
Kaz
Cheers!
Kaz
Yo... Cheers for the reply. I found a rust free shell for the drift project 2 weeks ago (YAY!) but am lookin for a daily driver now (ie, doesnt HAVE to have IRS)...
Not looking to spend much, but, another s12 would be handy so i can swap parts around. PM me ya mobs and ill come and check it out this week. Gotta have some reg. :laugh:
Nick.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
