#1 Bolt on type, need repair on one bend just before it attaches to the cat, eveything else is perfect working order, 3" piping and a 4" tip, full stainless system, i assume it will only cost $80 or so for a local shop to cut out the bend and make another mandrel bent corner (cheaper if pressure bent)
photos of system and a close up of the bend are here
$550
#2 Only a couple months old, hardly used, perfect condition, still under warranty, box receipts car charger etc etc all come with it, selling due to need of money for car payments would like to sell asap
specs as per here its the silver colour (you need to select the T600 from the top otherwise it auto brings up a random phone :D)
quick sale if possible please, phone is 100% only selling coz i need the money, its only about 2months old and have receipts and everything to prove it, open to inspection
Highest Bid $270 pickup/pp unix (from overclockers.com.au)
INSTANT SALE - $350!!!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
