SOLD
I am selling my Series 3 31 Wagon.
I am in the Bayside area...
Details Are as follows -:
# GXE pack
# Auto
# Power Steer
# Cold A/c
# Tow bar
# Factory Roof bars
# Blue Paint in fair condition
# 15" Ser 3 Ti Alloys With 4 good Tyres 80% (on car)
# 14" Steel wheels with Brand new Tyres & factory hub caps
no rego or road worthy, needs suspension & a battery for roadie as far as I know, Have not looked.
Over all drives good & condition is not too bad, need the car gone need money for other things...
$650 o.n.o.
Have a few other things for a sedan
R H R Series 3 Tail light $25 SOLD
Full Rear Garnish set $30 for the set or $15 for center $10 for each side (set under the tail lights & along under the boot lid off ser 3)
or take the lot for $680
Can arange delivery of the car at your cost depending on where u live (Trailer Hire & Fuel Cost)
Car With Ti Alloys
Car With 14" Steel Wheels Fitted
https://www.sau.com.au/forums/topic/134367-sold-deposit-taken/
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
