Hey guyz,
my radiator is leaking ..i see droplets of radiator fluids at the bottom of my car...
time for new radiator? or is there other ways to patch it back?
I juz got a second hand radiator from my dealer..sigh
roughly how much for an r33 gts ?
chock
https://www.sau.com.au/forums/topic/134524-re-radiator-help/
Oh..yeah
thanks guyz ..i will try to take a pic of where the leak is located...
i went to check on the car again..and noticed tat my entire spare of coolant has been used...
how long does does it normally take to use ur entire coolant..
chock
