Hi people,
I have a Genuine Japanese Katana Sword for sale.
Picture tells all.
Hasnt been used on anyone yet (LOL :D )
Very nice for display in the house.
Comes with display stand.
$200 ONO (RRP $290)
This Item is now Sold.
Thanks for everyones interest.
Its a good Sword, and now its in an even Beta Home.
MAD
Thats why they call me Happy Gabby
Edited by happygabby
https://www.sau.com.au/forums/topic/134640-sold/
Thanks for everyones interest, but this has been in my Garage for a long time,
its still new and the blade its still the same as is was when i got it.
I do have certifs for it, but my garage is so full of SH*T that it will take me forever to find it.
But i can Guarantee that it is Original and its in Awsome Nik.
Unfortunatly for people that are interstate, i wont be able to post, well not unless you want to get done for this "DEVINE" work.
i will take photos of the blade, will be on there in 20 mins
https://www.sau.com.au/forums/topic/134640-sold/#findComment-2503003
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
