  • Replies 87
Posted Images
I look better with the lights off ;)
No you look great just tired I hope you went home and got some sleep! :)
awesome pics jess!!! hahahaha.. you really captured drunk sam too :mad:
Really!!! :O I did try most came out ok :mad:
I put money on the fact that this thread would turn up :D
Soon as i saw you taking photos...
Yep couldnt help my self having trouble with the video tho probably a good thing for some peeps *wink* Andrew and Steveo :):mad:
Was a gooooood night... :D
Let's do that again!
Yeah was a great night I hope Sam had fun and will definatly have to do it again! :)
i wanna see that video!!! lol! :)
Me to I am really trying to post it I will find away Dam It!!! :)
hahaha.. did you end up finding out what really happened when Andrew and Steve went to the Toilets together?
Yeah they went to the pokies thats why they were gone so long they won toooo ;):O
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
