they're definately good value for money, but not for track or heavy performance applications.
i have them on mine. nylon sidewalls (as opposed to steel belted) means they can shake at high speeds, and crumple under hard braking.
i've had no issues with them, they were on the car when i got it, and will remain till they need replacing.
https://www.sau.com.au/forums/topic/135248-nankang-ns-2/#findComment-2516998
What do you guys think of Nankang NS-2 tyres? I heard they are a cheaper version of some Yokohama performance tyre
They're a "cheaper version of a Yokohama performance tyre" in the same way a Carmate fibreglass bodykit is a "cheaper version of a C-West carbon fibre aero kit".
I've driven on NS-2s, and in my experience they're great for keeping your rims off the bitumen. They don't grip too well, but if you're not making a lot of power or driving the car faster than the signposted speeds they're fine.
https://www.sau.com.au/forums/topic/135248-nankang-ns-2/#findComment-2521534
Agreed.
Two 15min sessions on these tyres around Oran Park GP circuit saw the rear belts showing, and the fronts almost showing too.
Car would squirm under braking and under power out of every corner. That said I'm not exactly making stock power.
https://www.sau.com.au/forums/topic/135248-nankang-ns-2/#findComment-2521819
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
