they're definately good value for money, but not for track or heavy performance applications.
i have them on mine. nylon sidewalls (as opposed to steel belted) means they can shake at high speeds, and crumple under hard braking.
i've had no issues with them, they were on the car when i got it, and will remain till they need replacing.
https://www.sau.com.au/forums/topic/135248-nankang-ns-2/#findComment-2516998
What do you guys think of Nankang NS-2 tyres? I heard they are a cheaper version of some Yokohama performance tyre
They're a "cheaper version of a Yokohama performance tyre" in the same way a Carmate fibreglass bodykit is a "cheaper version of a C-West carbon fibre aero kit".
I've driven on NS-2s, and in my experience they're great for keeping your rims off the bitumen. They don't grip too well, but if you're not making a lot of power or driving the car faster than the signposted speeds they're fine.
https://www.sau.com.au/forums/topic/135248-nankang-ns-2/#findComment-2521534
Agreed.
Two 15min sessions on these tyres around Oran Park GP circuit saw the rear belts showing, and the fronts almost showing too.
Car would squirm under braking and under power out of every corner. That said I'm not exactly making stock power.
https://www.sau.com.au/forums/topic/135248-nankang-ns-2/#findComment-2521819
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
